Adrino with multiple FSR inputs
Thank you in advance !
I want to make a project where for example; four FSR/Load sensors connected to Arduino, and the weight will output to either an LCD for each sensor, or there is one LCD that displays four quadrants for each of the sensors, showing weight of each individual sensor.
Which Arduino would you recommend I use ? Please advise. Schematics or any advice on how to do this efficiently and as slim/portable as possible would be ideal.
Very Respectfully, Alexander
Any Arduino can read 4 analog devices and write to an LCD.
How do I get the adriuno to output the weight of each individual sensor to the lcd ? Do i need an amplifier ?
Write code that takes one sensor value and print it to the LCD. Then have that code four times but using a different sensor and printing to a different part of the LCD.
No.
