adruino and internet interface..
good day to all of you… :slight_smile:
how can i use my arduino to get data ro send data via internet? any idea guys? something like tcp/ip … or anything…
thanks in advance… :slight_smile:
There are a few option - I suggest you check out the Lantronix XPort and, if you need it, LadyAda’s XPort shield.
Be aware that the “webserver” part of the XPort is limited - there is no server side code and the space is limited.
Regards,
Mike
You could also have a look at something like this: http://www.nuelectronics.com/estore/index.php?main_page=product_info&cPath=1&products_id=4&zenid=e70197afd8e5cfbba60fb119ff5264e5
It’s is quite limited due to the memory constraints of the arduino, but it does do client and server side and could suit your application. You may want to say a little more about what you want to do, otherwise its hard to give a meaningful answer to your question.
thanks a lot bigMike… ilove arduino and ilove this forum… :wink:
FWIW: Netduino / libw5100 - Netduino
–Phil.
