I'm trying to use the ADS1115 with the ESP32 to measure voltages. It is very accurate when connected to a source voltage but fluctuates in the 0.5V ot 0.6V range when nothing is connected. Some searching indicates that I may need to use a voltage divider with the input pin connected to the midpoint so it is not floating. This is a problem as I will not be able to read voltages below the midpoint of the voltage divider using the single end method. The Arduino ADC doesn't have this issue. Is there a way to fix this.
All CMOS inputs float if not connected, this is normal. Why is it be a problem that a floating input is reading random? I can't figure out what you mean by this:
Please describe the problem that you are actually trying to solve.
What voltage do you want to measure, from what circuit?
When writing this reply, I realized that once the sensor board is connected to the power supply board it will have a connected ground. Testing the sensor board (with the esp32 and ADS1115) by itself causes the problem. So I guess there is no problem once connected. Thanks for helping me think this through.
