Hello,
I am trying to use an interrupt to read an ADS1115 using an Arduino Uno board. The ADS1115 is connected to a single potentiometer and reads one value. I am using the Adafruit_ADS1x15 library.
I can read the ADS1115 using the library's single ended example:
#include <Adafruit_ADS1X15.h>
Adafruit_ADS1115 ads; /* Use this for the 16-bit version */
void setup(void)
Serial.println("Getting single-ended readings from AIN0..3");
Serial.println("ADC Range: +/- 6.144V (1 bit = 3mV/ADS1015, 0.1875mV/ADS1115)");
if (!ads.begin()) {
Serial.println("Failed to initialize ADS.");
while (1);
void loop(void)
int16_t adc0;
float volts0;
adc0 = ads.readADC_SingleEnded(0);
volts0 = ads.computeVolts(adc0);
Serial.println(volts0);
However, when I copy the code from the loop into the interrupt, it does not output anything into the serial monitor anymore.
int16_t adc0;
float volts0;
// counter and compare values
const uint16_t tl_load = 0;
const uint16_t tl_comp = 31250;
void setup(void) {
// reset timer 1 control reg A
TCCR1A = 0;
// set prescaler of 256
TCCR1B |= (1 << CS12);
TCCR1B &= ~(1 << CS11);
TCCR1B &= ~(1 << CS10);
// reset timer 1 and set compare value
TCNT1 = tl_load;
OCR1A = tl_comp;
// enable timer compare interrupt
TIMSK1 = (1 << OCIE1A);
// enable global interrupts
sei();
if (!ads.begin()) {
while (1);
void loop(void) {
delay(1000); // main code, waits when interrupt is not called
// interrupt
ISR(TIMER1_COMPA_vect) {
TCNT1 = tl_load; // sets timer to 0
I'm assuming that single ended mode is not compatible with my interrupt setup, but I don't understand the ADS1115's modes.
Thanks for any help! This is my first time working with embedded code and external ADCs so I'm not really knowledgeable on the microcontroller or the ADS1115.
