ADS124S08 data reading problem
Guys,
Recently i wish to shift from 22-bit ADC to 24 bit ADC. So I purchased TI's ADS124s08 which works on SPI. Though I couldn't read data from using Commands, I succeeded in getting results using a library found in Github(on Arduino Due)
My Problem is I am getting perfect results using Arduino Due. But when i uploaded same program on Arduino UNO ,I am getting erroneous results..
Why that happens? Is there any difference between SPIs in DUE and UNO..
What program would that be ?
the example program..
ADCTEST_working.ino (8.8 KB)
ADS124S08.cpp (9.7 KB)
ADS124S08.h (16.0 KB)
Please make it as easy as possible to provide help and post at least the .ino file here, using code tags when you do
See How to get the best out of this forum
main file
 * Project ADCTEST
 * Description: Simple example for ratiometric reading of a 4-wire PT100 sensor connected to AIN0, AIN1, AIN2 (according to TI app note SBAA180B)
 * Author: Jensa
 * Date: 23 Nov 2017
 #include "ADS124S08.h"
 float ohmTable[501] = {100,100.39,100.78,101.17,101.56,101.95,102.34,102.73,103.12,103.51,103.9,104.29,104.68,105.07,105.46,105.85,106.24,106.63,107.02,107.4,107.79,108.18,108.57,108.96,109.35,109.73,110.12,110.51,110.9,111.28,111.67,112.06,112.45,112.83,113.22,113.61,113.99,114.38,114.77,115.15,115.54,115.93,116.31,116.7,117.08,117.47,117.85,118.24,118.62,119.01,119.4,119.78,120.16,120.55,120.93,121.32,121.7,122.09,122.47,122.86,123.24,123.62,124.01,124.39,124.77,125.17,125.55,125.93,126.32,126.7,127.08,127.46,127.85,128.23,128.61,128.99,129.38,129.76,130.14,130.52,130.9,131.28,131.67,132.05,132.43,132.81,133.19,133.57,133.95,134.33,134.71,135.09,135.47,135.85,136.23,136.61,136.99,137.37,137.75,138.13,138.51,138.89,139.27,139.65,140.03,140.39,140.77,141.15,141.53,141.91,142.29,142.66,143.04,143.42,143.8,144.18,144.56,144.94,145.32,145.69,146.07,146.45,146.82,147.2,147.58,147.95,148.33,148.71,149.08,149.46,149.83,150.21,150.58,150.96,151.34,151.71,152.09,152.46,152.84,153.21,153.58,153.95,154.32,154.71,155.08,155.46,155.83,156.21,156.58,156.96,157.33,157.71,158.08,158.45,158.83,159.2,159.56,159.94,160.31,160.68,161.05,161.43,161.8,162.17,162.54,162.91,163.28,163.66,164.03,164.4,164.77,165.14,165.51,165.88,166.25,166.62,167,167.37,167.74,168.11,168.48,168.85,169.22,169.59,169.96,170.33,170.69,171.06,171.43,171.8,172.17,172.54,172.91,173.27,173.64,174.01,174.39,174.75,175.12,175.49,175.86,176.23,176.59,176.96,177.33,177.7,178.06,178.43,178.8,179.16,179.53,179.9,180.26,180.63,180.99,181.36,181.73,182.09,182.46,182.82,183.19,183.55,183.92,184.28,184.65,185.01,185.38,185.74,186.11,186.47,186.84,187.2,187.56,187.93,188.29,188.65,189.02,189.38,189.74,190.11,190.47,190.83,191.2,191.56,191.92,192.28,192.66,193.02,193.38,193.74,194.1,194.47,194.83,195.19,195.55,195.9,196.26,196.62,196.98,197.35,197.71,198.07,198.43,198.79,199.15,199.51,199.87,200.23,200.59,200.95,201.31,201.67,202.03,202.38,202.74,203.1,203.46,203.82,204.18,204.54,204.9,205.25,205.61,205.97,206.33,206.7,207.05,207.41,207.77,208.13,208.48,208.84,209.2,209.55,209.91,210.27,210.62,210.98,211.34,211.69,212.05,212.4,212.76,213.12,213.47,213.83,214.19,214.55,214.9,215.26,215.61,215.97,216.32,216.68,217.03,217.39,217.73,218.08,218.44,218.79,219.15,219.5,219.85,220.21,220.56,220.91,221.27,221.62,221.97,222.32,222.68,223.03,223.38,223.73,224.09,224.45,224.8,225.15,225.5,225.85,226.21,226.56,226.91,227.26,227.61,227.96,228.31,228.66,229.01,229.36,229.72,230.07,230.42,230.77,231.12,231.47,231.81,232.16,232.51,232.86,233.21,233.56,233.91,234.26,234.6,234.95,235.3,235.65,236,236.35,236.7,237.05,237.4,237.75,238.09,238.44,238.79,239.14,239.48,239.83,240.18,240.52,240.87,241.22,241.56,241.91,242.25,242.6,242.95,243.29,243.64,243.98,244.33,244.67,245.02,245.36,245.71,246.05,246.4,246.74,247.09,247.43,247.78,248.12,248.46,248.81,249.15,249.5,249.84,250.18,250.53,250.89,251.21,251.55,251.9,252.24,252.59,252.94,253.28,253.62,253.96,254.3,254.65,254.99,255.33,255.67,256.01,256.35,256.7,257.04,257.38,257.72,258.06,258.4,258.74,259.08,259.42,259.76,260.1,260.44,260.78,261.12,261.46,261.8,262.14,262.48,262.83,263.17,263.5,263.84,264.18,264.52,264.86,265.2,265.54,265.87,266.21,266.55,266.89,267.22,267.56,267.9,268.24,268.57,268.91,269.25,269.58,269.92,270.26,270.59,270.93,271.27,271.6,271.94,272.27,272.61,272.95,273.28,273.62,273.95,274.29,274.62,274.96,275.29,275.63,275.96,276.31,276.64,276.97,277.31,277.64,277.98,278.31,278.64,278.98,279.31,279.64,279.98,280.31,280.64,280.98};
ADS124S08 adc;
uint8_t statusOld = -1;
long lastSample;
int counter;
int sampleNumber = 1;
int lastButtonStatus = 0;
int useIDAC = 0;
// setup() runs once, when the device is first turned on.
  delay(100);
  adc.begin();
  delay(100);
  adc.sendCommand(RESET_OPCODE_MASK);
  delay(100);
  /* print out the chip name */
  if( adc.regRead(ID_ADDR_MASK) == 0x01 )
    Serial.println("You have an ADS124S06\n");
    Serial.println("You have an ADS124S08\n");
  delay(10);
  configureAdc();
  Serial.println("...............................");
  long now = millis();
  uint8_t status;
  // Check if it's X seconds since last conversion
  if( now - lastSample > 25 ){
    //Serial.print(sampleNumber);
    //Serial.print(" ");
    lastSample = now;
    status = readData();
    uint8_t rdy    = bitRead(status, 6);
    uint8_t por    = bitRead(status, 7);
    if( statusOld != status )
      statusOld = status;
      Serial.print("status: ");
      Serial.print( status,BIN );
      Serial.print(" POR: ");
      Serial.print( bitRead(status, 7) );
      Serial.print(" RDY: ");
      Serial.println( rdy );
      // the chip restarted (for some reason) so clear the POR flag, but only when ready
      if( por == 1 && rdy == 0){
        // clear the POR flag and reconfigure
        bitWrite(status, 7, 0);
        adc.regWrite(STATUS_ADDR_MASK, status);
        configureAdc();
        // print debug info so we can see if this worked
        status = adc.regRead( STATUS_ADDR_MASK );
        Serial.print( "POR cleared? " );
        Serial.println(status,BIN);
    sampleNumber++;
  delay(100);
void configureAdc()
  // Make sure the device is awake
  adc.sendCommand( WAKE_OPCODE_MASK );
  // use channel 1 as positive and channel 2 as negative input
  adc.regWrite( INPMUX_ADDR_MASK, ADS_P_AIN1 + ADS_N_AIN2 );
  // set PGA to 8x
  adc.regWrite( PGA_ADDR_MASK, ADS_PGA_ENABLED + ADS_GAIN_4 );
  // The IDAC will only work if we enable the internal reference (ref Datasheet 9.3.7)
  adc.regWrite( REF_ADDR_MASK, ADS_REFINT_ON_ALWAYS + ADS_REFSEL_P0 );
  // use channel 3 as IDAC 1 (excitation current source)
  adc.regWrite( IDACMUX_ADDR_MASK, ADS_IDAC1_A0 + ADS_IDAC2_OFF );
  // set IDAC 1 to output 500uA
  adc.regWrite( IDACMAG_ADDR_MASK, ADS_IDACMAG_1000 );
  // Turn on status for debugging
  adc.regWrite( SYS_ADDR_MASK, ADS_SENDSTATUS_ENABLE );
  adc.reStart();
  delay(10);
  regMap2();
uint8_t readData()
	uint8_t dStatus = 0;
	uint8_t dData;
	uint8_t dCRC = 0;
	int data = 0;
	/* Read out the results  */
	data = adc.dataRead(&dStatus, &dData, &dCRC);
	 * Need to determine if Status and/or CRC is enabled to transmit as desired
	if((adc.registers[SYS_ADDR_MASK] & 0x01) == DATA_MODE_STATUS)
		if((adc.registers[SYS_ADDR_MASK] & 0x02) == DATA_MODE_CRC)
		//	Serial.printlnf("Conversion Data 0x%06x with Status 0x%02x and CRC 0x%02x.", data, dStatus, dCRC);
      //sSerial.printlnf("Conversion Data 0x%06x with Status 0x%02x. DEC %02d", data, dStatus,data);
	else if((adc.registers[SYS_ADDR_MASK] & 0x02) == DATA_MODE_CRC)
	//	Serial.printlnf("Conversion Data 0x%06x with CRC 0x%02x.", data, dCRC);
  //  Serial.printlnf("Conversion Data 0x%06x.", data);
  float ADC_fullscale = 67108864;// (ADC_fullscale = 2^23 * PGA_Value)
  float resistance = ((float)data*3300)/ADC_fullscale;
  Serial.print("data: ");
  Serial.println((float)data);Serial.print("resistance: ");
  Serial.println(resistance);
  resistance=(resistance/100)-1;
  float temp= (resistance * (255.8723 + resistance * (9.6 + resistance * 0.878)));
	/* Set ADC back to the previous configuration */
	//adc.sendCommand(STOP_OPCODE_MASK);
	//adc.sendCommand(SLEEP_OPCODE_MASK);
  return dStatus;
void regMap(void)
	unsigned int index;
	char cTemp;
	Serial.println("Register Contents");
	Serial.println("---------------------");
	for(index=0; index < 18 ; index++)
		cTemp = adc.regRead(index);
		//Serial.printlnf("Register 0x%02x = 0x%02x", index, cTemp);
void regMap2(void)
	unsigned int index;
	uint8_t cTemp[18];
  adc.readRegs(0,18,cTemp);
		//Serial.printlnf("Register 0x%02x = 0x%02x", index, cTemp[index] );
float getCelcius( float ohmMeasured )
   float below, above, interpol;
   int i;
   for( i=0; i<501; i++ )
     if( ohmMeasured < ohmTable[i] )
       above = ohmTable[i];
       below = ohmTable[i-1];
   float range = above-below;
   float remain = ohmMeasured-below;
   float percent = (remain / range);
   interpol = i - 1 + percent;
   return interpol;
#define bitRead(value, bit) (((value) >> (bit)) & 0x01)
#define bitSet(value, bit) ((value) |= (1UL << (bit)))
#define bitClear(value, bit) ((value) &= ~(1UL << (bit)))
#define bitWrite(value, bit, bitvalue) (bitvalue ? bitSet(value, bit) : bitClear(value, bit))
.cpp file
/* --COPYRIGHT--,BSD
 * Copyright (c) 2016, Texas Instruments Incorporated
 * All rights reserved.
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions
 * are met:
 * *  Redistributions of source code must retain the above copyright
 *    notice, this list of conditions and the following disclaimer.
 * *  Redistributions in binary form must reproduce the above copyright
 *    notice, this list of conditions and the following disclaimer in the
 *    documentation and/or other materials provided with the distribution.
 * *  Neither the name of Texas Instruments Incorporated nor the names of
 *    its contributors may be used to endorse or promote products derived
 *    from this software without specific prior written permission.
 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
 * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
 * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
 * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
 * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
 * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
 * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
 * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
 * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
 * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
 * --/COPYRIGHT--*/
 * This class is based on the ADS124S08.c provided by TI and adapted for use with
 * Particle Photon and other Arduino-like MCU's.
 * Note that the confusingly named "selectDeviceCSLow"
 * actually selects the device and that "releaseChipSelect" deselects it. Not obvious
 * from the naming, but according to the datasheet CS is active LOW.
 * Writes the nCS pin low and waits a while for the device to finish working before
 * handing control back to the caller for a SPI transfer.
void ADS124S08::selectDeviceCSLow(void){
	digitalWrite( CS_PIN, LOW );
 * Pulls the nCS pin high. Performs no waiting.
void ADS124S08::releaseChipSelect(void){
	digitalWrite( CS_PIN, HIGH );
 * Initializes device for use in the ADS124S08 EVM.
 * \return True if device is in correct hardware defaults and is connected
ADS124S08::ADS124S08(void)
	pinMode( CS_PIN, OUTPUT );
	pinMode( START_PIN, OUTPUT );
	pinMode( RESET_PIN, OUTPUT );
	pinMode( CKEN_PIN, OUTPUT );
	pinMode( DRDY_PIN, INPUT );
	digitalWrite( START_PIN, LOW );
	digitalWrite( RESET_PIN, HIGH );
	digitalWrite( CKEN_PIN, LOW );
	/* Default register settings */
	registers[ID_ADDR_MASK] 			= 0x08;
	registers[STATUS_ADDR_MASK] 	= 0x80;
	registers[INPMUX_ADDR_MASK]		= 0x01;
	registers[PGA_ADDR_MASK] 			= 0x00;
	registers[DATARATE_ADDR_MASK] = 0x14;
	registers[REF_ADDR_MASK] 			= 0x10;
	registers[IDACMAG_ADDR_MASK] 	= 0x00;
	registers[IDACMUX_ADDR_MASK] 	= 0xFF;
	registers[VBIAS_ADDR_MASK] 		= 0x00;
	registers[SYS_ADDR_MASK]			= 0x10;
	registers[OFCAL0_ADDR_MASK] 	= 0x00;
	registers[OFCAL1_ADDR_MASK] 	= 0x00;
	registers[OFCAL2_ADDR_MASK] 	= 0x00;
	registers[FSCAL0_ADDR_MASK] 	= 0x00;
	registers[FSCAL1_ADDR_MASK] 	= 0x00;
	registers[FSCAL2_ADDR_MASK] 	= 0x40;
	registers[GPIODAT_ADDR_MASK] 	= 0x00;
	registers[GPIOCON_ADDR_MASK]	= 0x00;
	fStart = false;
	releaseChipSelect();
	deassertStart();
void ADS124S08::begin()
	SPI.begin();
//	SPI.setBitOrder(MSBFIRST);
//	SPI.setDataMode( SPI_MODE1 );
//	SPI.setClockSpeed( 1000000 );
	#if defined (SPI_HAS_TRANSACTION)
		mySPISettings = SPISettings(1000000, MSBFIRST, SPI_MODE1);
	#endif
 * Reads a single register contents from the specified address
 * \param regnum identifies which address to read
char ADS124S08::regRead(unsigned int regnum)
	int i;
  uint8_t ulDataTx[3];
  uint8_t ulDataRx[3];
	ulDataTx[0] = REGRD_OPCODE_MASK + (regnum & 0x1f);
	ulDataTx[1] = 0x00;
	ulDataTx[2] = 0x00;
	selectDeviceCSLow();
		SPI.beginTransaction(mySPISettings);
	#endif
	for(i = 0; i < 3; i++)
		ulDataRx[i] = SPI.transfer(ulDataTx[i]);
	if(regnum < NUM_REGISTERS)
			registers[regnum] = ulDataRx[2];
		SPI.endTransaction();
	#endif
	//Serial.printlnf("regRead tx: %02x %02x %02x",ulDataTx[0],ulDataTx[1],ulDataTx[2]);
	//Serial.printlnf("regRead rx: %02x %02x %02x",ulDataRx[0],ulDataRx[1],ulDataRx[2]);
	return ulDataRx[2];
 * Reads a group of registers starting at the specified address
 * \param regnum is addr_mask 8-bit mask of the register from which we start reading
 * \param count The number of registers we wish to read
 * \param *location pointer to the location in memory to write the data
void ADS124S08::readRegs(unsigned int regnum, unsigned int count, uint8_t *data)
	int i;
  uint8_t ulDataTx[2];
	ulDataTx[1] = count-1;
	SPI.transfer(ulDataTx[0]);
	SPI.transfer(ulDataTx[1]);
	for(i = 0; i < count; i++)
		data[i] = SPI.transfer(0);
		if(regnum+i < NUM_REGISTERS)
			registers[regnum+i] = data[i];
 * Writes a single of register with the specified data
 * \param regnum addr_mask 8-bit mask of the register to which we start writing
 * \param data to be written
void ADS124S08::regWrite(unsigned int regnum, unsigned char data)
	ulDataTx[0] = REGWR_OPCODE_MASK + (regnum & 0x1f);
	ulDataTx[1] = 0x00;
	ulDataTx[2] = data;
	SPI.transfer(ulDataTx[2]);
	//Serial.printlnf("regWrite tx: %02x %02x %02x",ulDataTx[0],ulDataTx[1],ulDataTx[2]);
	return;
 * Writes a group of registers starting at the specified address
 * \param regnum is addr_mask 8-bit mask of the register from which we start writing
 * \param count The number of registers we wish to write
 * \param *location pointer to the location in memory to read the data
void ADS124S08::writeRegs(unsigned int regnum, unsigned int howmuch, unsigned char *data)
	unsigned int i;
	ulDataTx[1] = howmuch-1;
	for(i=0; i < howmuch; i++)
		SPI.transfer( data[i] );
	return;
 * Sends a command to the ADS124S08
 * \param op_code is the command being issued
void ADS124S08::sendCommand(uint8_t op_code)
	SPI.transfer(op_code);
	return;
 * Sends a STOP/START command sequence to the ADS124S08 to restart conversions (SYNC)
void ADS124S08::reStart(void)
	sendCommand(START_OPCODE_MASK);
	return;
 * Sets the GPIO hardware START pin high (red LED)
void ADS124S08::assertStart()
	fStart = true;
	digitalWrite(START_PIN ,HIGH);
 * Sets the GPIO hardware START pin low
void ADS124S08::deassertStart()
	fStart = false;
	digitalWrite(START_PIN, LOW);
 * Sets the GPIO hardware external oscillator enable pin high
void ADS124S08::assertClock()
	digitalWrite(CKEN_PIN, 1);
 * Sets the GPIO hardware external oscillator enable pin low
void ADS124S08::deassertClock()
	digitalWrite(CKEN_PIN, LOW);
int ADS124S08::rData(uint8_t *dStatus, uint8_t *dData, uint8_t *dCRC)
	int result = -1;
	// according to datasheet chapter 9.5.4.2 Read Data by RDATA Command
	sendCommand(RDATA_OPCODE_MASK);
	// if the Status byte is set - grab it
	uint8_t shouldWeReceiveTheStatusByte = (registers[SYS_ADDR_MASK] & 0x01) == DATA_MODE_STATUS;
	if( shouldWeReceiveTheStatusByte )
		dStatus[0] = SPI.transfer(0x00);
		//Serial.print("status: ");
		//Serial.print(dStatus[0]);
	// get the conversion data (3 bytes)
	uint8_t data[3];
	data[0] = SPI.transfer(0x00);
	data[1] = SPI.transfer(0x00);
	data[2] = SPI.transfer(0x00);
	result = data[0];
	result = (result<<8) + data[1];
	result = (result<<8) + data[2];
	//Serial.printlnf(" 1: %02x 2: %02x, 3: %02x = %d", data[0], data[1], data[2], result);
	// is CRC enabled?
	uint8_t isCrcEnabled = (registers[SYS_ADDR_MASK] & 0x02) == DATA_MODE_CRC;
	if( isCrcEnabled )
		dCRC[0] = SPI.transfer(0x00);
	return result;
 * Read the last conversion result
int ADS124S08::dataRead(uint8_t *dStatus, uint8_t *dData, uint8_t *dCRC)
	uint8_t xcrc;
	uint8_t xstatus;
	int iData;
	if((registers[SYS_ADDR_MASK] & 0x01) == DATA_MODE_STATUS)
		xstatus = SPI.transfer(0x00);
		//Serial.print("0:");
		//Serial.print(xstatus);
		dStatus[0] = (uint8_t)xstatus;
	uint8_t data[3];
	Serial.print(" 1:");
	Serial.print(data[0]);
	Serial.print(" 2:");
	Serial.print(data[1]);
	Serial.print(" 3:");
	Serial.println(data[2]);
	iData = data[0];
	iData = (iData<<8) + data[1];
	iData = (iData<<8) + data[2];
	if((registers[SYS_ADDR_MASK] & 0x02) == DATA_MODE_CRC)
		xcrc = SPI.transfer(0x00);
		dCRC[0] = (uint8_t)xcrc;
	return iData ;
.h file
 * are met:
 * --/COPYRIGHT--*/
 * ADS124S08.h
#ifndef ADS124S08_H_
#define ADS124S08_H_
#include <SPI.h>
/* Start definitions */
#define NUM_REGISTERS 18
 * Address masks used for register addressing with
 * either a REGRD of REGWR mask
#define ID_ADDR_MASK		0x00
#define STATUS_ADDR_MASK	0x01
#define INPMUX_ADDR_MASK	0x02
#define PGA_ADDR_MASK		0x03
#define DATARATE_ADDR_MASK	0x04
#define REF_ADDR_MASK		0x05
#define IDACMAG_ADDR_MASK	0x06
#define IDACMUX_ADDR_MASK	0x07
#define VBIAS_ADDR_MASK		0x08
#define SYS_ADDR_MASK		0x09
#define OFCAL0_ADDR_MASK	0x0A
#define OFCAL1_ADDR_MASK	0x0B
#define OFCAL2_ADDR_MASK	0x0C
#define FSCAL0_ADDR_MASK	0x0D
#define FSCAL1_ADDR_MASK	0x0E
#define FSCAL2_ADDR_MASK	0x0F
#define GPIODAT_ADDR_MASK	0x10
#define GPIOCON_ADDR_MASK	0x11
/* Opcode masks (or "Commands" if you will...) */
#define NOP_OPCODE_MASK		0x00
#define WAKE_OPCODE_MASK	0x02
#define SLEEP_OPCODE_MASK	0x04
#define RESET_OPCODE_MASK	0x06
#define START_OPCODE_MASK	0x08
#define STOP_OPCODE_MASK	0x0A
#define SFOCAL_OPCODE_MASK	0x19
#define SYOCAL_OPCODE_MASK	0x16
#define SYGCAL_OPCODE_MASK	0x17
#define RDATA_OPCODE_MASK	0x12
#define REGRD_OPCODE_MASK	0x20
#define REGWR_OPCODE_MASK	0x40
/* Register sub masks */
/* ADS124S08 Register 0 (ID) Definition
 *   Bit 7   |   Bit 6   |   Bit 5   |   Bit 4   |   Bit 3   |   Bit 2   |   Bit 1   |   Bit 0
 *        			RESERVED[4:0]      			 			 |  	      DEV_ID[2:0]
/* Define ID (revision) */
#define ADS_ID_A				0x00
#define ADS_ID_B				0x80
/* Define VER (device version) */
#define ADS_124S08				0x00
#define ADS_124S06				0x01
#define ADS_114S08				0x04
#define ADS_114S06				0x05
/* ADS124S08 Register 1 (STATUS) Definition */
/*   Bit 7   |   Bit 6   |   Bit 5   |   Bit 4   |   Bit 3   |   Bit 2   |   Bit 1   |   Bit 0
 *   FL_POR  |    nRDY   | FL_P_RAILP| FL_P_RAILN| FL_N_RAILP| FL_N_RAILN| FL_REF_L1 | FL_REF_L0
#define ADS_FL_POR				0x80
#define ADS_RDY					0x40
#define ADS_FL_P_RAILP			0x20
#define ADS_FL_P_RAILN			0x10
#define ADS_FL_N_RAILP			0x08
#define ADS_FL_N_RAILN			0x04
#define ADS_FL_REF_L1			0x02
#define ADS_FL_REF_L0			0x10
/* ADS124S08 Register 2 (INPMUX) Definition */
 *         			MUXP[3:0]   				 |       			MUXN[3:0]
/* Define the ADC positive input channels (MUXP) */
#define ADS_P_AIN0				0x00
#define ADS_P_AIN1				0x10
#define ADS_P_AIN2				0x20
#define ADS_P_AIN3				0x30
#define ADS_P_AIN4				0x40
#define ADS_P_AIN5				0x50
#define ADS_P_AIN6				0x60
#define ADS_P_AIN7				0x70
#define ADS_P_AIN8				0x80
#define ADS_P_AIN9				0x90
#define ADS_P_AIN10				0xA0
#define ADS_P_AIN11				0xB0
#define ADS_P_AINCOM			0xC0
/* Define the ADC negative input channels (MUXN)*/
#define ADS_N_AIN0				0x00
#define ADS_N_AIN1				0x01
#define ADS_N_AIN2				0x02
#define ADS_N_AIN3				0x03
#define ADS_N_AIN4				0x04
#define ADS_N_AIN5				0x05
#define ADS_N_AIN6				0x06
#define ADS_N_AIN7				0x07
#define ADS_N_AIN8				0x08
#define ADS_N_AIN9				0x09
#define ADS_N_AIN10				0x0A
#define ADS_N_AIN11				0x0B
#define ADS_N_AINCOM			0x0C
/* ADS124S08 Register 3 (PGA) Definition */
 *   		DELAY[2:0]		     	 |      PGA_EN[1:0]      |              GAIN[2:0]
/* Define conversion delay in tmod clock periods */
#define ADS_DELAY_14			0x00
#define ADS_DELAY_25			0x20
#define ADS_DELAY_64			0x40
#define ADS_DELAY_256			0x60
#define ADS_DELAY_1024			0x80
#define ADS_DELAY_2048			0xA0
#define ADS_DELAY_4096			0xC0
#define ADS_DELAY_1				0xE0
/* Define PGA control */
#define ADS_PGA_BYPASS			0x00
#define ADS_PGA_ENABLED			0x08
/* Define Gain */
#define ADS_GAIN_1				0x00
#define ADS_GAIN_2				0x01
#define ADS_GAIN_4				0x02
#define ADS_GAIN_8				0x03
#define ADS_GAIN_16				0x04
#define ADS_GAIN_32				0x05
#define ADS_GAIN_64				0x06
#define ADS_GAIN_128			0x07
/* ADS124S08 Register 4 (DATARATE) Definition */
 *   G_CHOP  |    CLK    |    MODE   |   FILTER  | 				  DR[3:0]
#define ADS_GLOBALCHOP			0x80
#define ADS_CLKSEL_EXT			0x40
#define ADS_CONVMODE_SS			0x20
#define ADS_FILTERTYPE_LL		0x10
/* Define the data rate */
#define ADS_DR_2_5				0x00
#define ADS_DR_5				0x01
#define ADS_DR_10				0x02
#define ADS_DR_16				0x03
#define ADS_DR_20				0x04
#define ADS_DR_50				0x05
#define ADS_DR_60				0x06
#define ADS_DR_100				0x07
#define ADS_DR_200				0x08
#define ADS_DR_400				0x09
#define ADS_DR_800				0x0A
#define ADS_DR_1000				0x0B
#define ADS_DR_2000				0x0C
#define ADS_DR_4000				0x0D
/* ADS124S08 Register 5 (REF) Definition */
 *	  FL_REF_EN[1:0]	 | nREFP_BUF | nREFN_BUF | 		REFSEL[1:0]		 | 		REFCON[1:0]
#define ADS_FLAG_REF_DISABLE	0x00
#define ADS_FLAG_REF_EN_L0		0x40
#define ADS_FLAG_REF_EN_BOTH	0x80
#define ADS_FLAG_REF_EN_10M		0xC0
#define ADS_REFP_BYP_DISABLE	0x20
#define ADS_REFP_BYP_ENABLE		0x00
#define ADS_REFN_BYP_DISABLE	0x10
#define ADS_REFN_BYP_ENABLE		0x00
#define ADS_REFSEL_P0			0x00
#define ADS_REFSEL_P1			0x04
#define ADS_REFSEL_INT			0x08
#define ADS_REFINT_OFF			0x00
#define ADS_REFINT_ON_PDWN		0x01
#define ADS_REFINT_ON_ALWAYS	0x02
/* ADS124S08 Register 6 (IDACMAG) Definition */
 * FL_RAIL_EN|	  PSW	 |     0     | 		0	 | 			    	IMAG[3:0]
#define ADS_FLAG_RAIL_ENABLE	0x80
#define ADS_FLAG_RAIL_DISABLE	0x00
#define ADS_PSW_OPEN			0x00
#define ADS_PSW_CLOSED			0x40
#define ADS_IDACMAG_OFF			0x00
#define ADS_IDACMAG_10			0x01
#define ADS_IDACMAG_50			0x02
#define ADS_IDACMAG_100			0x03
#define ADS_IDACMAG_250			0x04
#define ADS_IDACMAG_500			0x05
#define ADS_IDACMAG_750			0x06
#define ADS_IDACMAG_1000		0x07
#define ADS_IDACMAG_1500		0x08
#define ADS_IDACMAG_2000		0x09
/* ADS124S08 Register 7 (IDACMUX) Definition */
 *                    I2MUX[3:0]                 |                   I1MUX[3:0]
/* Define IDAC2 Output */
#define ADS_IDAC2_A0			0x00
#define ADS_IDAC2_A1			0x10
#define ADS_IDAC2_A2			0x20
#define ADS_IDAC2_A3			0x30
#define ADS_IDAC2_A4			0x40
#define ADS_IDAC2_A5			0x50
#define ADS_IDAC2_A6			0x60
#define ADS_IDAC2_A7			0x70
#define ADS_IDAC2_A8			0x80
#define ADS_IDAC2_A9			0x90
#define ADS_IDAC2_A10			0xA0
#define ADS_IDAC2_A11			0xB0
#define ADS_IDAC2_AINCOM		0xC0
#define ADS_IDAC2_OFF			0xF0
/* Define IDAC1 Output */
#define ADS_IDAC1_A0			0x00
#define ADS_IDAC1_A1			0x01
#define ADS_IDAC1_A2			0x02
#define ADS_IDAC1_A3			0x03
#define ADS_IDAC1_A4			0x04
#define ADS_IDAC1_A5			0x05
#define ADS_IDAC1_A6			0x06
#define ADS_IDAC1_A7			0x07
#define ADS_IDAC1_A8			0x08
#define ADS_IDAC1_A9			0x09
#define ADS_IDAC1_A10			0x0A
#define ADS_IDAC1_A11			0x0B
#define ADS_IDAC1_AINCOM		0x0C
#define ADS_IDAC1_OFF			0x0F
/* ADS124S08 Register 8 (VBIAS) Definition */
 *  VB_LEVEL | 	VB_AINC  |  VB_AIN5  |  VB_AIN4  |  VB_AIN3  |  VB_AIN2  |  VB_AIN1  |  VB_AIN0
#define ADS_VBIAS_LVL_DIV2		0x00
#define ADS_VBIAS_LVL_DIV12		0x80
/* Define VBIAS here */
#define ADS_VB_AINC				0x40
#define ADS_VB_AIN5				0x20
#define ADS_VB_AIN4				0x10
#define ADS_VB_AIN3				0x08
#define ADS_VB_AIN2				0x04
#define ADS_VB_AIN1				0x02
#define ADS_VB_AIN0				0x01
/* ADS124S08 Register 9 (SYS) Definition */
 *			   SYS_MON[2:0]			 |	   CAL_SAMP[1:0]     |  TIMEOUT  | 	  CRC	 | SENDSTAT
#define ADS_SYS_MON_OFF			0x00
#define ADS_SYS_MON_SHORT		0x20
#define ADS_SYS_MON_TEMP		0x40
#define ADS_SYS_MON_ADIV4		0x60
#define ADS_SYS_MON_DDIV4		0x80
#define ADS_SYS_MON_BCS_2		0xA0
#define ADS_SYS_MON_BCS_1		0xC0
#define ADS_SYS_MON_BCS_10		0xE0
#define ADS_CALSAMPLE_1			0x00
#define ADS_CALSAMPLE_4			0x08
#define ADS_CALSAMPLE_8			0x10
#define ADS_CALSAMPLE_16		0x18
#define ADS_TIMEOUT_DISABLE		0x00
#define ADS_TIMEOUT_ENABLE		0x04
#define ADS_CRC_DISABLE			0x00
#define ADS_CRC_ENABLE			0x02
#define ADS_SENDSTATUS_DISABLE	0x00
#define ADS_SENDSTATUS_ENABLE	0x01
/* ADS124S08 Register A (OFCAL0) Definition */
 *                                         OFC[7:0]
/* ADS124S08 Register B (OFCAL1) Definition */
 *                                         OFC[15:8]
/* ADS124S08 Register C (OFCAL2) Definition */
 *                                         OFC[23:16]
/* ADS124S08 Register D (FSCAL0) Definition */
 *                                         FSC[7:0]
/* ADS124S08 Register E (FSCAL1) Definition */
 *                                         FSC[15:8]
/* ADS124S08 Register F (FSCAL2) Definition */
 *                                         FSC[23:16]
/* ADS124S08 Register 10 (GPIODAT) Definition */
 *                      DIR[3:0]    			 | 					DAT[3:0]
/* Define GPIO direction (0-Output; 1-Input) here */
#define ADS_GPIO0_DIR_INPUT		0x10
#define ADS_GPIO1_DIR_INPUT		0x20
#define ADS_GPIO2_DIR_INPUT		0x40
#define ADS_GPIO3_DIR_INPUT		0x80
/* Define GPIO data here */
/* ADS124S08 Register 11 (GPIOCON) Definition */
 *     0	 |	   0	 |	   0	 |	   0     |                    CON[3:0]
/* Define GPIO configuration (0-Analog Input; 1-GPIO) here */
/* Lengths of conversion data components */
#define DATA_LENGTH			3
#define STATUS_LENGTH		1
#define CRC_LENGTH			1
 * The time we have to wait for the CS GPIO to actually
 * pull down before we start sending SCLKs
#define CHIP_SELECT_WAIT_TIME	0
/* Flag to signal that we are in the process of collecting data */
#define DATA_MODE_NORMAL	0x00
#define DATA_MODE_STATUS	0x01
#define DATA_MODE_CRC		0x02
 /* The clock rate of the internal XTAL... */
#define DEVICE_ICLK 16384000
/* Set the SPI SCLK speed */
#define SPI_SPEED 1000000
                 // 5000000
 * The TIVA has a 4 to 16 bit word size, to handle  32 bit words the TIVA needs to assemble
 * two groups of words together.  32 bits comprises of 2x16 words (or 4x8 words).
#define SPI_WORD_SIZE 8
/* Chip select feedthrough GPIO - we hand feed chip select so overages may be pumped out. */
#define CS_PIN  6
#define DRDY_PIN  -1
/* GPIO definitions. */
#define START_PIN  A1
#define RESET_PIN  A0
#define CKEN_PIN  -1
#define SPI_HAS_TRANSACTION 0
  static SPISettings mySPISettings;
#endif
class ADS124S08
	// Device command prototypes
	public:
		ADS124S08(void);
		void begin();
		char regRead(unsigned int regnum);
		void readRegs(unsigned int regnum, unsigned int count, uint8_t *data);
		void regWrite(unsigned int regnum, unsigned char data);
		void writeRegs(unsigned int regnum, unsigned int howmuch, unsigned char *data);
		void reStart(void);
		void sendCommand(uint8_t op_code);
		int  rData(uint8_t *dStatus, uint8_t *dData, uint8_t *dCRC);
		int  dataRead(uint8_t *dStatus, uint8_t *dData, uint8_t *dCRC);
		void selectDeviceCSLow(void);
		void releaseChipSelect(void);
		void assertStart(void);
		void deassertStart(void);
		void assertClock(void);
		void deassertClock(void);
		bool converting;
		uint8_t registers[NUM_REGISTERS];
  private:
		bool fStart;
		void DRDY_int(void);
		uint8_t _drdy_pin;
		uint8_t _start_pin;
		uint8_t _reset_pin;
#endif /* ADS124S08_H_ */
uno output
data: 2904.00
resistance: 0.14
data: 2894.00
resistance: 0.14
data: 2897.00
resistance: 0.14
data: 2901.00
resistance: 0.14
data: 2893.00
resistance: 0.14
data: 2898.00
resistance: 0.14
data: 2896.00
resistance: 0.14
data: 2894.00
resistance: 0.14
data: 2890.00
resistance: 0.14
data: 2896.00
resistance: 0.14
data: 2901.00
resistance: 0.14
Due Output
data: 2558614.00
resistance: 125.82
data: 2558620.00
resistance: 125.82
data: 2558644.00
resistance: 125.82
data: 2558637.00
resistance: 125.82
data: 2558640.00
resistance: 125.82
data: 2558639.00
resistance: 125.82
data: 2558639.00
resistance: 125.82
data: 2558642.00
resistance: 125.82
data: 2558637.00
resistance: 125.82
data: 2558649.00
resistance: 125.82
data: 2558649.00
resistance: 125.82
