Hello Everyone,
I have interfaced ADS1256 high precision AD/DA board with Arduino Uno.
Before I was able to read data from ADS1256 but suddenly I am receiving continuously 0 i am not able to figure out the actual issue. Below I am attaching code with this query.
I checked SPI signals on oscilloscope all signals are coming properly. Please guide me as i am bit new to external ADC interfacing.
Actually my requirement is to get minimum 100 Samples per second, I was getting data but not so accurately.
//https://forum.arduino.cc/index.php?topic=441637.0
//while (digitalRead(rdy)) {} // wait for ready_line to go low
#include<SPI.h>
#define ADS_SPISPEED 16000000
#define ADS_RST_PIN 8 //ADS1256 reset pin
#define ADS_RDY_PIN 9 //ADS1256 data ready
#define ADS_CS_PIN 10 //ADS1256 chip select
// 11, 12 and 13 are taken by the SPI
byte Command = 0x00;
byte mux_reg = 0x01;
byte status_reg = 0x00; // address (datasheet p. 30)
byte status_data = 0x01;//0x01 //status: Most Significant Bit First, Auto-Calibration Disabled, Analog Input Buffer Disabled
byte adcon_reg = 0x02; //A/D Control Register (Address 02h)
byte adcon_data = 0x24; // 0 01 00 000 => Clock Out Frequency = fCLKIN, Sensor Detect OFF, gain 1
byte drate_reg = 0x03; // Choosing Data Rate register = third register.
byte drate_data = 0b10000010;//=1000SPS//10000010=100 SPS // 11000000 = 3,750SPS
SPI.begin();
SPI.beginTransaction(SPISettings(ADS_SPISPEED, MSBFIRST, SPI_MODE1));
SPI.setClockDivider(SPI_CLOCK_DIV8);
pinMode(ADS_CS_PIN, OUTPUT);
pinMode(ADS_RDY_PIN, INPUT);
pinMode(ADS_RST_PIN, OUTPUT);
digitalWrite(ADS_RST_PIN, LOW);
delayMicroseconds(100); // LOW at least 4 clock cycles of onboard clock. 100 microsecons is enough
digitalWrite(ADS_RST_PIN, HIGH); // now reset to deafult values
digitalWrite(ADS_RDY_PIN,LOW);
Write_Register(status_reg, status_data);
Write_Register(adcon_reg, adcon_data);
Write_Register(drate_reg, drate_data);
void Write_Register(byte Address, byte data)
digitalWrite(ADS_CS_PIN, LOW);
SPI.transfer(0x50|Address);
SPI.transfer(Command);//cmd
SPI.transfer(data);
SPI.endTransaction();
digitalWrite(ADS_CS_PIN,HIGH);
delayMicroseconds(20);//20//2.5
uint32_t adc_val[8] = {0,0,0,0,0,0,0,0}; // unsigned long is on 32 bits //unsigned long
for(int i=0; i<8; i++)
// while (digitalRead(ADS_RDY_PIN)) {} ;
byte Channel = i;
Write_Register(mux_reg, (Channel << 4) | (1 << 3));
SPI.transfer(0xFC);
delayMicroseconds(20);//10
SPI.transfer(0x00);
SPI.transfer(0x03); // Read Data Continuously 0000 0011 (03h)
adc_val[i] = SPI.transfer(0);
adc_val[i] <<= 8; //shift to left
adc_val[i] |= SPI.transfer(0);
adc_val[i] <<= 8;
if (adc_val[i] > 0x7fffff)
adc_val[i] = 16777216 - adc_val[i]; //do 2's complement, discard sign
Serial.print(adc_val[i]);
Serial.print("\t");
digitalWrite(ADS_CS_PIN, HIGH);
delay(1);
