ADS1292R ECG/RESPIRATION SHIELD Error Help
Hi-
i am trying to get this “ADS1292R ECG/RESPIRATION SHIELD FOR ARDUINO- V2” to work but i am currently getting this error message. im not sure what to change as i was given the code. I attached the three files necessary for the program to upload and the info can be found in the link above.
Thanks
Chaim
C:\Users\Chaim\AppData\Local\Temp\build8b129a7b0a9a8c8d5247f982f94b94bd.tmp\libraries\Protocentral_ADS1292R\ads1292r.cpp.o: In function `ads1292r::ads1292_Read_Data()':
C:\Program Files (x86)\Arduino\libraries\Protocentral_ADS1292R/ads1292r.cpp:25: multiple definition of `ads1292r::ads1292_Read_Data()'
C:\Users\Chaim\AppData\Local\Temp\build8b129a7b0a9a8c8d5247f982f94b94bd.tmp\sketch\ads1292r.cpp.o:C:\Users\Chaim\AppData\Local\Temp\build8b129a7b0a9a8c8d5247f982f94b94bd.tmp\sketch/ads1292r.cpp:25: first defined here
C:\Program Files (x86)\Arduino\libraries\Protocentral_ADS1292R/ads1292r.cpp:25: multiple definition of `ads1292r::ads1292_Reset()'
C:\Users\Chaim\AppData\Local\Temp\build8b129a7b0a9a8c8d5247f982f94b94bd.tmp\sketch\ads1292r.cpp.o:C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI/SPI.h:209: first defined here
C:\Program Files (x86)\Arduino\libraries\Protocentral_ADS1292R/ads1292r.cpp:25: multiple definition of `ads1292r::ads1292_Disable_Start()'
C:\Program Files (x86)\Arduino\libraries\Protocentral_ADS1292R/ads1292r.cpp:25: multiple definition of `ads1292r::ads1292_Enable_Start()'
C:\Program Files (x86)\Arduino\libraries\Protocentral_ADS1292R/ads1292r.cpp:25: multiple definition of `ads1292r::ads1292_Hard_Stop()'
C:\Program Files (x86)\Arduino\libraries\Protocentral_ADS1292R/ads1292r.cpp:25: multiple definition of `ads1292r::ads1292_SPI_Command_Data(unsigned char)'
C:\Program Files (x86)\Arduino\libraries\Protocentral_ADS1292R/ads1292r.cpp:25: multiple definition of `ads1292r::ads1292_Start_Data_Conv_Command()'
C:\Program Files (x86)\Arduino\libraries\Protocentral_ADS1292R/ads1292r.cpp:25: multiple definition of `ads1292r::ads1292_Soft_Stop()'
C:\Program Files (x86)\Arduino\libraries\Protocentral_ADS1292R/ads1292r.cpp:25: multiple definition of `ads1292r::ads1292_Start_Read_Data_Continuous()'
C:\Program Files (x86)\Arduino\libraries\Protocentral_ADS1292R/ads1292r.cpp:25: multiple definition of `ads1292r::ads1292_Stop_Read_Data_Continuous()'
C:\Program Files (x86)\Arduino\libraries\Protocentral_ADS1292R/ads1292r.cpp:25: multiple definition of `ads1292r::ads1292_Reg_Write(unsigned char, unsigned char)'
C:\Program Files (x86)\Arduino\libraries\Protocentral_ADS1292R/ads1292r.cpp:25: multiple definition of `ads1292r::ads1292_Init()'
collect2.exe: error: ld returned 1 exit status
Using library Protocentral_ADS1292R in folder: C:\Program Files (x86)\Arduino\libraries\Protocentral_ADS1292R (legacy)
Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
exit status 1
Error compiling.
ads1292r.cpp (5.46 KB)
ads1292r.h (3.07 KB)
ECG-Respiration-Plot.ino (4.03 KB)
Do this:
  • Sketch > Show Sketch folder
  • Delete ads1292r.cpp and ads1292r.h
  • Close and then reopen ECG-Respiration-Plot.ino
