ADSL Cable for 5v sensors?
Hello folks,
I'm monitoring irrigation equipment with 5v sensors - pressure, flow meter, halls effect sensor to measure rpm on pelton wheels and also 5v temp sensors. I'm having to make a few of these, and the way I have been running the cables directly into the project boxes through a cable gland is becoming a hassle, especially if you need to remove the sensor for whatever reason.
My sensors are not far from the Arduino - avg. 1/2m and 1m at the most. Would it be feasible to use ASDL cable with RJ11 plugs and jacks over this distance? Or would this guage cause a voltage drop big enough to affect the readings?
Keep the connectors perfectly dry and they’ll be fine. Wind blown rain and early morning condensation are double trouble.
I have been down the same path, and after many hours of research I have concluded that good quality cheap waterproof connectors don’t exist. For some reason manufacturers charge 10-20x the price for simply adding a plastic shell with an O ring.
The only inexpensive connectors that I would consider barely acceptable are the 5 pin inline plug/socket combinations sold for use with LED garden lights.
You're referring to these?
Looks like a good option, thanks. Just wish I could find them at a better price.
heinburgh:
SP13 & SP17 Std Panel Mount IP68 Waterproof Multipole Plug & Socket Connectors | eBay
These were the kind I found.
https://www.aliexpress.com/item/1pair-Male-Female-Plug-2-Pin-4-pin-LED-Waterproof-Connector-Cable-White-For-Single-Color/32779495314.html
They aren't precision built so expect to wrestle with the pin alignment.
Just found these:
GBP 2.42, looks like ok quality and a bit quicker delivery than all the way from China by snailmail
