Hello everyone!
I'm working on advanced Daytime Running Lights module for my car. As I'm a beginner in electronic I need some help
I want to use Arduino Nano, but later I may replace it with ATMega 328 itself. This is not important now.
So, what the module does?
Input:
-car battery +10-15V (usually +12.7-13.8V)
-GND
-ignition
-open car impulse
-close car impulse
-5 signals from headlights (signal lights, low beam, high beam, both indicators)
-3 buttons
-signal lights IN (WIRE1,2)
Output:
-6 LED lights - 12V 150mA each
-signal lights OUT
-separate +5V for buttons
-external relay
Functions:
-power on on open car impulse or ignition signal
-keep itself turned on (D0)
-turn off signal lights (D1)
-read 5 headlight and 2 open/close car 12V signals through opto-isolators and shift register
-read 3 buttons through shift register
-control 6 LED lights using PWM through Darlington Array
-control one external relay through Darlington Array (D13)
-user configurable using DIP-switch, potentiometer, button, and build-in led (D13)
I would like ask you to check my schema. I need to valid all resistors, capacitors and diodes.
I'm not sure if input current is properly filtered (L1, D4, D5, C1).
I don't know if I used proper diodes to protect relays and opto-isolators (D6, D7, D9-15).
I don't know if my short circuit protection for buttons input is good (D16-18).
I don't know if I used proper fuses. E.g. 500mA for 450mA assumed current.
Thanks in advance for any help!
