I'm trying to write a library. The thing is, it should be quite versatile and not limited to the Arduino. But it seems that a library for Arduino can only consist of one(!) C++ class and its header in the library's root directory. No subdirectories (at least stuff in there isn't found by the build system).
Is it possible to coax the arduino build system to accept subdirectories and somehow specify what to build? Can someone point me to an explanation how the build system works in the first place?
Its not that the library is limited to a single class, so much as it is limited to a single cpp file. You can code multiple classes within that cpp file. I don't know of a way to have multiple directories of files in a library...
wanderson:
Ok. Do I have to use C++ at all or could I do all this in plain C too?
no, the utility folder is hardcoded in the ide and is the only allowed name, and if i remember correctly, it only works is lib is in arduino default folder (and i think it's a bad practice mix "original" and "3° part" lib)
