Advanced Serial input?
I couldn't help notice that no one has coded a advanced serial input library yet? With current available code I'm finding it very hard to read strings of commands entered to the arduino via serial.
Ive made a terminal style input in asm before on the HCS12 how hard would it be on the Arduino? I want to be able to communicate via serial different string commands for example If you typed flush_Ser the serial would be flushed Set_midiCon1 7 would set midi controller 1 to act as a main volume control
anyone know how to use the serial interrupts on the arduino? im looking for a good serial tutorial but cant find anything decent?
Study the code in hardware\cores\arduino\hardwareserial.h and hardwareserial.cpp They use the interrupts for serial receiving.
Here is what I have working so far, I have the flu so I might have made some mistakes
//Advanced Serial Input By Moogle
//Max input length is 10, so "SetA 110000"
#define LEDpin 13
boolean ledon = false;
#define DEBUG true
// Variables:
char incomingByte[10] = "test";      // for incoming serial data
boolean printed = false;
  Serial.flush(); // for good luck ?
  pinMode(LEDpin, OUTPUT);
  digitalWrite(LEDpin, ledon);
  invertLED();
  if(DEBUG)
    Serial.println("Advance Serial Input Debug Enabled");
  getSerial();
  void invertLED();
void getSerial()
  if( Serial.available() > 0) {// was something typed?
    while (Serial.available() > 0) {
      //there is something in the buffer
      for( int i =0; i <10; i++){
        //only loop 10 times dont over flow array
        // read the incoming byte:
       incomingByte[i] = Serial.read();
       invertLED();
    DEBUGPrint();//Print the info typed
void invertLED() {
  //Blink the led for visual reference
  digitalWrite(LEDpin,ledon);
  ledon =!ledon; //Invert current Led state
  delay(100); //Delay to give buffer a chance
void DEBUGPrint()
  if( DEBUG) {//Will only print if the debug is enabled
      Serial.print("I received: ");
       //only loop 10 times dont try to print outside the array
        if(incomingByte[i]!=-1){
        //sometimes not all 10 characters are used
          Serial.print(char(incomingByte[i]));
        else{
        //dont print null kill the loop
          i=10;
will read a word from the user.
TODO:
process the words
split words from numbers; example"Speed= 100"
convert to a re-usable library
ok i started working on the library and ran into a problem
In function AdvancedSerial': AdvancedSerial.cpp:14: undefined reference to AdvancedSerial::invertLED()’
o: In function loop': Temporary_8586_9130.cpp:14: undefined reference to AdvancedSerial::getSerial()’
Couldn’t determine program size: \serialtest.hex’: No such file
I cant figure out what i did wrong??
the AdvancedSerial.h
#ifndef AdvancedSerial_h
#define AdvancedSerial_h
#include "WProgram.h"
class AdvancedSerial
  public:
   AdvancedSerial(boolean Debug, int Speed);
   void getSerial();
   void DEBUGPrint();
   char* GetString();
  private:
  char incomingByte[];
  byte StringSize;
  boolean ledon;
  boolean DEBUG;
  int _speed;
  void invertLED();
#endif
the AdvancedSerial.cpp
#include "WConstants.h"
#include "AdvancedSerial.h"
#define LEDpin 13
AdvancedSerial::AdvancedSerial(boolean Debug, int Speed)
  _DEBUG=Debug;
  _speed = Speed;
  Serial.begin(_speed);
  StringSize = 10;
  ledon = false;
  incomingSTR[] = "test";
  invertLED();
  if(_DEBUG)
char* GetString()
  return incomingSTR;
void invertLED() {
void getSerial()
      for( int i =0; i <StringSize; i++){
       incomingSTR[i] = Serial.read();
       invertLED();
void DEBUGPrint()
  if( _DEBUG) {//Will only print if the debug is enabled
        if(incomingSTR[i]!=-1){
          Serial.print(char(incomingSTR[i]));
        else{
          i=StringSize;
any ideas?
In AdvancedSerial.cpp change...
void invertLED() {
...to...
void AdvancedSerial::invertLED() {
Repeat for the remaining member functions.
Good luck, Brian
O.o!!!
I ended up with 32 pages of errors then??
what did I do wrong? Can someone Guide me?
If you post your .h and .cpp here: www.arduino.pastebin.com I'll sure have a look. :)
Remember to post links ;)
CPP file http://www.arduino.pastebin.com/f4741e33 .h file http://www.arduino.pastebin.com/f4b75f402
Working sketch I'm trying to convert to a library http://www.arduino.pastebin.com/fac58442
TY in advance :)
no help yet?
http://www.alexanderbrevig.com/hosting/arduino/libraries/AdvancedSerial.zip
Compiles and works. At least, it does what I think your pastebin-code tried to do. :)
Let me know when you've given it a try.
[TESTED ON IDE 0015]
Works great!! tyvm :slight_smile:
now to expand functionality and usefulness
Im probably making a very noob error here, who can spot it? (I keep thinking vb.net X_x not c++)
#include <AdvancedSerial.h>
AdvancedSerial advser = AdvancedSerial();
char* recieved;
char* lastcommand;
  advser.begin(false,9600);
  Serial.println("AlphaBeta is King");
  Serial.println(advser.getString());
void loop(){
  advser.getSerial();
  recieved = advser.getString();
  if(recieved != lastcommand)
    if(recieved == "error?")
     Serial.println("there was not a error!");
  lastcommand= recieved;
I don't know how I missed this thread, but, alas I did.
I'm on the warpath to create a more well-rounded serial library. I've posted a thread http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1245549766 in which I describe creating an new underlying class (transparent to end users) which simply enhances any and all current serial classes.
With the new subclass, you can do things like:
mynumber = Serial.getnumber(HEX)
which gets an ASCII string of hexadecimal characters, and converts it into a number (stored into mynumber).
or
Serial.getstring(mystring, 40);
or
Serial.getstring(mystring, 40, '\n')
which gets a string (into mystring), either 40 characters long (no more, no less), or in the second case, gets a string up to a terminator (in this case a new line).
You can download the libraries from here: http://mediafire.com/Arduino
Simply put the files (from Libraries/SerialComm/) into the arduino/hardware/cores/arduino folder/directory. This will overwrite the existing HardwareSerial.h/.cpp - so if you want, you should create a backup of the files.
I'll be adding an updated version of NewSoftSerial as well (it just requires changing the inheritance to SerialComm, and adding a new method called "peek").
I want to add a printf (scaled down from the existing one in stdio), but need to gauge the interest in it. Feedback welcome.
b
nice work!
are you going to fix it so we can put multiple variables on one line
example:
int apples = 5;
int sold = 12;
Serial.Println(“I have " << apples << " in my inventory, and sold " << sold << " apples today.”);
