advanced transistor operation
I'm trying to find some information on advanced transistor operation, in particular reverse polarity behavior of NPNs.
I've recently learned that for some transistors, reverse breakdown between the emitter and base is non-destructive.
http://jlnlabs.online.fr/cnr/negosc.htm
However my (untested) belief is Vceo is a destructive limit. For example if I connect the emitter of a 2n3904 to 100v and the collector to ground, I believe I'll fry it, since Vceo is 40V.
But for Vcbo is it non-destructive like Vebo?
Lastly I've been trying to find out more about reverse-polarized operation where the base voltage is higher than emitter, and with the collector voltage higher than the base. According to transistor theory all transistors will work in this mode, and if I understand it correctly gain is always <1, since collector current is always the sum of base and emitter current.
I did some tests with a 2n3904 and the reverse polarized voltage drop (Vec-sat) was ~1v, compared to ~0.1v for Vce-sat forward polarized. The datasheet lists 0.2V as the maximum for Vce-sat with 10mA of collector current, but I don't see anything in the datasheet for reverse polarized. Does anyone know where I can find that information (short of actually testing the transistors)?
The article doesn't state that back-biasing a base-emitter junction is absolutely "non-destructive."
Like any diode there definitely is a limit, a reverse breakdown voltage.
The article does state that there is a region, a range, within which a certain effect can be appreciated.
P-N junction breakdown doesn't mean anything actually breaks, or that magic smoke is released, etc.
From p–n junction - Wikipedia
The strength of the depletion zone electric field increases as the reverse-bias voltage increases. Once the electric field intensity increases beyond a critical level, the p–n junction depletion zone breaks down and current begins to flow, usually by either the Zener or the avalanche breakdown processes. Both of these breakdown processes are non-destructive and are reversible, as long as the amount of current flowing does not reach levels that cause the semiconductor material to overheat and cause thermal damage.
OK, but when I look at diode i-v curves in avalance breakdown, the reverse voltage does not decrease with an increase of current - unlike the so-called negative resistance of the collector-base junction. Is there some diodes that behave this way, or is it for some reason unique to transistors?
If you hit reverse breakdown with enough current, the transistor is toast. Limit the current
enough and its basically just a zener diode (because just like a zener the base-emitter
junction is heavily doped and a very narrow depletion zone). The base metalization and
bond wires are not designed for large currents like those of the emitter and collector, note.
I've taken out a 15A power NPN transistor with negative Vbe, just a short pulse was enough...
Sure. Pretty much all diodes can operate "backwards." Zener diodes are a particular type that is DESIGNED to operate that way.
You usually have to have some other mechanism for limiting current (and thus power dissipation) to a safe amount.
Reverse-biased base/emitter junctions are sometimes used as random noise generators: Random Sequence Generator based on Avalanche Noise
westfw:
But a zener stops conducting when the voltage drops below the breakdown voltage, but with the reverse emitter-base junction it will continue to conduct if the voltage drops below Vebo. Conduction only stops when the current drops to near zero.
Is that the difference between zener breakdown and avalanche breakdown?
No, look at the I/V curve of a real device.
Low voltage zeners (genuine zeners) have a very soft knee. Higher voltage devices
(which are just avalanche-breakdown devices disguised as zener-effect diodes) have
sharper knees.
If you want a decent sharp response then use a zener buffered with a BJT - resistor R from
emitter to base, zener from base to collector. The zener current is approx 0.6/R, so you
can choose which part of the curve, and once the collector is more than Vz+0.6V the
BJT turns on and takes most of the current, buffering the zener voltage.
Are you sure? There are 4-layer devices that behave that way (tunnel diodes, "sidactors", SCRs in breakdown), but normal reverse-biased single junctions behave more like zeners. The original article you linked is reverse-biasing the CE connection (three layers, I guess...)
Grumpy_Mike:
Are you being pedantic and referring to the normal near-zero reverse leakage of all diodes, or something material that I'm missing?
westfw:
I wasn't paying close enough attention to that (reversing CE not BE) - thanks for pointing that out. So the reverse emitter base junction on a 2n3904 should act like a 6V zener. The reverse CE, however, should not.
Today I found another article that says basically the same thing, and shows some nice scope shots of the zener vs reverse transistor knee.
http://cr4.globalspec.com/thread/72501
Sidactors are cool, BTW. You can convert a disposable camera flash to a repeating strobe with one component.
Somewhat similar components are used for overvoltage protection of telco circuits (and lots of other things), but they have someone different IV curves...
