Hey all,
I had a few friends ask me about a state machine that I made for the serial out example.
I was new to the Arduino, and I wanted to play around with the 'serial' class.
... So this is for them, but I'm happy for any comments/suggestions...
* SUMMARY
//LDU
This program is designed to print out
all the ASCII keys as an intro to
Serial communication.
It is based on <arduino.cc/en/Tutorial/ASCIITable>
and been carefully studied for my understanding, and
then updated to enclude some more advanced techniques.
ASCII table
Prints out byte values in all possible formats:
as raw binary values
as ASCII-encoded decimal, hex, octal, and binary values
For more on ASCII, see http://www.asciitable.com and
http://en.wikipedia.org/wiki/ASCII
* PROPERTIES
//Functions in project
void PrintMenu(void);
void GetInputState(void);
void SetupPrintingInstance(struct PrintingInstance *PrintWindow, int Start, int Finish);
void PrintLine(struct PrintingInstance *PrintWindow);
//Constants for project
const int FirstPrintableChar = '!';
const int LastPrintableChar = '~';
const int FirstNumber = '0';
const int LastNumber = '9';
const int FirstLowerLetter = 'a';
const int LastLowerLetter = 'z';
const int FirstCapitalLetter = 'A';
const int LastCapitalLetter = 'Z';
//Enumerations for program
//(This is a customised variable type)
enum State //What State the program is in
InitialiseObjects,
PromptPrintingList,
WaitingForInput,
PrintAllChar,
PrintNumbers,
PrintLower,
PrintCapital,
AfterPrintingToScreen,
unknown
//Objects for program
struct PrintingInstance //A window of characters to print
int StartingChar;
int FinishChar;
int CurrentChar;
//Declare printing window object
PrintingInstance FullPrintingWindow;
PrintingInstance NumberPrintingWindow;
PrintingInstance LowerPrintingWindow;
PrintingInstance CapitalPrintingWindow;
//Declare Program state
State PrintingState;
//Declare variable for user input
int UserInput;
* SETUP
//Set up port speed
//Prints title which explains what is to be explained
Serial.println("ASCII Table ~ Character Map");
//Set up initial state
PrintingState = InitialiseObjects;
* MAIN STATE MACHINE
switch(PrintingState)
case InitialiseObjects:
//initialise "FullPrintingWindow"
SetupPrintingInstance(&FullPrintingWindow, FirstPrintableChar, LastPrintableChar);
//initialise "NumberPrintingWindow"
SetupPrintingInstance(&NumberPrintingWindow, FirstNumber, LastNumber);
//initialise "LowerPrintingWindow"
SetupPrintingInstance(&LowerPrintingWindow, FirstLowerLetter, LastLowerLetter);
//initialise "CapitalPrintingWindow"
SetupPrintingInstance(&CapitalPrintingWindow, FirstCapitalLetter, LastCapitalLetter);
case PromptPrintingList:
//Prompt user with options
PrintMenu();
case WaitingForInput:
GetInputState();
case PrintAllChar:
//Print all characters
PrintLine(&FullPrintingWindow);
case PrintNumbers:
//Print all numbers
PrintLine(&NumberPrintingWindow);
case PrintLower:
//Print all lower letters
PrintLine(&LowerPrintingWindow);
case PrintCapital:
//Print all Capital Letters
PrintLine(&CapitalPrintingWindow);
case AfterPrintingToScreen:
//Do not do anything
default:
//Restore nonprinting state
PrintingState = AfterPrintingToScreen;
* METHODS
// Address of a PrintingInstance object, start position
// and finish position is passed into function
//Set up domain of Charactors wanted to print
PrintWindow->StartingChar = Start;
PrintWindow->FinishChar = Finish;
PrintWindow->CurrentChar = Start;
//Update State
PrintingState = PromptPrintingList;
void PrintMenu()
//Menu for user to select from:
Serial.println("What would you like to see?");
Serial.println("1 - All printable ASCII characters");
Serial.println("2 - All numbers");
Serial.println("3 - All lower case letters");
Serial.println("4 - All capital letters");
//Update State
PrintingState = WaitingForInput;
void GetInputState()
int IncomingCharacter;
while(Serial.available() == 0)
//Do Nothing...
//Get users incoming character
IncomingCharacter = Serial.read();
//match input to printing state
switch(IncomingCharacter)
case '1':
//User wants to print out all ASCII Characters
PrintingState = PrintAllChar;
case '2':
//User wants to print out all ASCII Numbers
PrintingState = PrintNumbers;
case '3':
//User wants to print out all ASCII lower letters
PrintingState = PrintLower;
case '4':
//User wants to print out all ASCII Capital Letters
PrintingState = PrintCapital;
default:
//User has made an error
//Address of a PrintingInstance object is passed into function
//Prints a line based on what character is in
//object currently.
//Note that "->" is used when dealing with structure elements
//and pointers.
//Declare what first print is going to be
Serial.print("Character: ");
//Print out current byte
Serial.print(PrintWindow->CurrentChar, BYTE);
//Declare what the second print will be
Serial.print(", Dec: ");
//Print out byte as Decimal (base 10)
//(Note that the ", DEC" is not actually
//needed by default)
Serial.print(PrintWindow->CurrentChar, DEC);
//Same with third print
Serial.print(", Hex: ");
Serial.print(PrintWindow->CurrentChar, HEX);
//Same with forth print
Serial.print(", Oct: ");
Serial.print(PrintWindow->CurrentChar, OCT);
//Same with fith print
Serial.print(", Binary: ");
Serial.println(PrintWindow->CurrentChar, BIN);
//If last character is found, switch to
//a non printing state
if(PrintWindow->CurrentChar == PrintWindow->FinishChar)
//Increment current ASCII Byte
PrintWindow->CurrentChar++;
And I have never posted anything on exhibition, so I thought that it would be different!
