Hello,
I have a running project for an unattended alarm system. It triggers an alarm via a Songle relay module.
Is done with Arduino UNO Genuino.
The relay has a flyback protection diode cross the coil.
The power source is regulated by a L7812 regulator with the correct capacitors to decouple. It provides 12.2 vdc to Vin. I can modify this power unit and feed 5 or 9 volt if necessary.
Measured voltages @ 5 vdc and 3.3 vdc pins are correct.
I had this week a board that is damaged. The 16u2 converter is dead.
When I posted a help for this case, I got this answer:
Did the board used to work? If it did, and it now does not work, and you've checked with a different cable, the 16u2 may be damaged; this seem to happen surprisingly often, particularly when working with external power supplies and/or powering inductive loads from the arduino power supply; the 16u2 seems to be very vulnerable to damage from abusing the power rails, and it's unclear why this is the case.
I have read many guides to select an Arduino, including Adafruit
But this vulnerability problem is not considered, I understand is a very particular case.
The question is:
What Arduino model is more suitable from this point of view ?
Nano ? Pro ? Intel 101? Other ?
I only use three digital pins. Sketch is simple and short.
One final idea, after reading a lot about UNO and standalone use of ATmega328P.
If my 16u2 is burned, the 328 should still run the last loaded sketch.
That is not the case. Not only the UNO does not communicate via USB, but the board itself does not run the last uploaded module.
I think the way to test could be to remove the 328 from UNO, install it in a standalone mode with power, crystal, capacitors, etc, and test if it runs or not the last uploaded sketch.
Am I right at this point?
Thanks a lot,
Have a nice day,
Horacio
