I have a DS3231 RTC in my circuit design. I have not included the 200R and in4148 as usually included in the RTC modules, as this is apparently a bad way to charge the LIR2032.
I could use a standard 2032, but I would like to have a rechargeable option (yes, I know... the RTC will take years to run down the standard 2032).
The Vbat pin on a DS3231 can take 2.3v - 5.5v, so a 3.6v NiMh would seem suitable (and I have loads of them).
But, I cannot find a suitable circuit to run from 5v to charge the battery. I hunted around the RS site for battery management IC's, but they are biblically expensive (£8 ish) and not exactly what I need.
Anyone have an ideas or at least a basis on an approach?
Many thanks
I would just use a resistor to feed current into the battery. Based on your description from 5V to 3V6 and with negliable load maybe 1mA, so (5-3V6) / 0.001 = 1k4 Ohms, or thereabouts.
You are correct, lithium batteries are very fussy about how you charge them. NiMh you can just trickle some current into them indefinitely. As your load is tiny you just need enough current to keep it charged.
I have my Arduino feeding a MCP23017 multiplexer over I2C, which in turn uses it's outputs to switch NPN transistors through a 1k to the base.
The ground is obviously switched on when the MCP23017 pin is high.
Is it essential to have a 10k to pull that base low when off? I just don't have the room on my PCB.
Is the low signal from the multiplexer good enough to hold those transistors off?
Otherwise my PCB just ain't big enough.... that that then impacts other things.
Bipolar transistors have a low input resistance, they need current to be fed into the base for anything to happen, no current, nothing happens.
MOSFETs, which I think are confusing you, have a very, very high input resistance to the gate, so high you can consider it to be open circuit for most purposes. They do have a little bit of capacitance on the gate though. The result is that unless you actively pull charge out of the gate with something (such as the resistor you suggested) it will stay there and the MOSFET will not behave as you expect. Because of their high input resistance they pick up noise from the environment if left floating (not connected) and end up with some random voltage on the gate and an unpredictable output on the drain.
