I need some general advice for a project I would like to commence.
I would like to create a small device that can be "attached/placed" on top of a mechanical keyboard key, with the sole purpose of this device being to press the key it is attached to. I will then code how often to push the button, frequency etc.
I figure I need some kind of motor, but I am not aware of the most suitable type of motor for this application.
I thought I articulated my question sufficiently to not require additional info on background / purpose, but happy to provide- I want to essentially emulate keystrokes as if made by a user with no ability to distinguish the difference. This means no additional usb connections to PC, not virtualized keyboards, no AHK scripting etc. The device has to push the button - this is the primary constraint to the project.
I have looked through various types of servos, steppers and linear actuators, but I cant seem to find one that would do the trick (ie. Sufficient "push distance, quite quick, small form factor, able to be mounted easily on a 3D printed design etc.).
