Advice For my university embeddded project radio control dog with animatronics
Sorry about the copy from main section , looked a good idea to post this here too
For my university embeddded project I need to make something electro mechanical and programmed ie pic, electronics and something that does something.
Mine will be a radio or wire control cat or dog that pees and does other things as I have an interest in special effects.
I am clueless about radio control… form what Ive picked up though you need a transmiter, reciever, battery packs and servos… 2.4 systems are better as lock onto one reciever and transmitter. More channels are good.
I have no idea how brands compare or what I should be looking for in a purchase on Ebay
these are some I have been looking at
http://www.ebay.co.uk/itm/140934667014?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
http://www.ebay.co.uk/itm/2-4ghz-handset-6ch-matching-receiver-setup-boats-but-fine-planes-/261185905436?_trksid=p5197.m1992&_trkparms=aid%3D111000%26algo%3DREC.CURRENT%26ao%3D1%26asc%3D14%26meid%3D6434923150233549380%26pid%3D100015%26prg%3D1006%26rk%3D1%26sd%3D261185905436%26
http://www.ebay.co.uk/itm/171008276394?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
http://www.westbourne-model.co.uk/acatalog/Robbe_F_Series_Radios.html
http://www.ebay.co.uk/itm/221202310350?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
Also some were described as missing ariel how hard and expensive is it to replace these, what all will I need, can any servo work with any controller, what should I ask sellers, whata a good deal and what should I avoid? etc
As said looking intially at my project but then looking to use this for other effects projects etc. Plus a few pranks
Also what is a good way to merge this with a pic project using a PIC 16F819
Advice please asap as eyeing up various deals on ebay ending soon
You want a 2.4GHz system; anything in the MHz range is antiquated.
If you're just looking for a straight up recommendation I'd point to the Turnigy 9x. You can find lots of reviews on this with a little searching; it's quite popular.
Once you have a tx/rx you can start here -
Duane B
rcarduino.blogspot.com
