Advice/Help with Programming Prompted Case Switch (within Switch) over Serial
Thanks in advance.
Looking for guidance in programming a prompted serial display.
Question: I am trying to have a prompted screen based on case switch over serial. The goal is to follow several prompts to achieve the specific result.
Problem: In my case '1' switch, I cannot seem to get the serial to let me follow the second prompt for 'a' and 'b'. When I select '1', it will automatically complete the case and break out, not letting me select the other selections.
I thought that the below code would let me wait for a prompt.
while (Serial.available() == 0) {
then this line would recognize what was entered
inByte = Serial.read();
again pointing to a switch case that I could follow over serial.
This shouldn't be this difficult, what am I missing?
int numpressed;
int inByte;
  Serial.print("Select '0', then hit enter");
  Serial.print("Select '1', then hit enter");
  Serial.print("Select '2', then hit enter");
  Serial.print("Select '3', then hit enter");
  Serial.print("What number would you like to select?");
  numpressed = Serial.read();
  switch (numpressed) {
    case '0':
      Serial.print("Pressed 0");
    case '1':
      Serial.print("Pressed 1");
      Serial.print("Select 'a', then hit enter");
      Serial.print("Select 'b', then hit enter");
            switch (inByte) {
              case 'w':
                Serial.print("Pressed a");
              case 'v':
                Serial.print("Pressed b");
              default:
                Serial.print("Invalid Entry");
    case '2':
      Serial.print("Pressed 2");
      //do something
    case '3':
      Serial.print("Pressed 3");
      //do something
yes on case 1 you fist wait for the Serial.port(input) then print on Serial(print).
change them to . first show serial output(print) then wait for serial input(read).
case '1':
            switch (inByte) {
              case 'w':
              case 'v':
              default:
