I wish to control (control: just to reset the programming) arduino uno with a remote.
I want to avoid using push button on the board, I wish to replace the usage with a remote performing same function..
I want that to happen with 14 arduino uno using a single remote.
RANGE: between 20-30 meters
By: bluetooth/RF/etc as you suggest.
PLEASE GUIDE
THANK YOU!
nikhilbhardwaj I suggest you start a thread of your own because what you request is not relevant to the subject of this thread.
Tom.....
moderator: topic split off
nikhilbhardwaj:
PLEASE GUIDE
THANK YOU!
Buy a cheap remote control from DX or similar. Use the receiver relay across the reset.
The address can be set for each remote so you can set them all the same if required.
Weedpharma
