advice needed for arduino as diesel injection brain...
PeterH is correct, I did not write the sketch properly. I need a signature under my avatar that says "Warning Novice on board!" .
I rewrote the return sketch, I think it is correct this time. Sorry for the mistake I made earlier.
const int ledPin =  13;      // the number of the LED pin
// Variables will change:
int DonesAnswer = 0;           // variable to pass "done" to
long previousMillis = 0;        // will store last time LED was updated
long interval = 1200;           // interval at which to blink (milliseconds)
  // set the digital pin as output:
  pinMode(ledPin, OUTPUT);
  unsigned long currentMillis = millis();
  if(currentMillis - previousMillis > interval)
    // save the last time you blinked the LED
    previousMillis = currentMillis;
   DonesAnswer = whatdonedoes();   // transfer "done" to DonesAnswer using the function
    Serial.print("done = ");
    Serial.println(DonesAnswer);
    digitalWrite(ledPin, DonesAnswer);
////////////////////////////////function with a return called done//////////
int whatdonedoes()
  static int done = 0;  //set done to static int
  // if the LED is off turn it on and vice-versa:
  if (done == 1)
    done = 0;
    done = 1;
  return done;
