I'm new to this tech but thought I'd get my feet wet by asking a question on data collection and logging.
I have a 240 volt AC 60 hz single phase 33 kw generator that I thought it would be interesting to capture various operating parameters and store as a csv file on a server that would be imported into a sql data base and reported on by a web site.
But first things first, I want to be able to Accurately measure the 240 vac output (2 decimal places or 240.00 vac) or the pair of 120 vac outputs. I also want to measure amperage draw, frequency, calculate wattage, engine parameters such as water temp, oil pressure, 12 v battery voltage, battery charge rate (amps), date and & time for starters. I'd also Like to incorporate alarms such as low or no oil pressure and low water level, over temp with a display on screen and a relay to open or close.
I like to display this info on a color lcd screen in real time as well and log these parameters to a file every 10 seconds or so.
The question is :
Is the Arduino the right platform or do I need to look elsewhere? If yes, then what sort of extra circuits might I need.
Also the generator is about 100ft away, how might this distance effect the measurement accuracy?
This is a very big project.
You are going to have to definitely break this into manageable parts.
You may want to look at a Bobuino2, complete with terminals made by Crossroads, for the final board. http://www.crossroadsfencing.com/BobuinoRev17/
Yes sensors are needed, where do I buy them and what am I looking for . I want to start small and just dsplay the volts and amps on a screen. The generator is located 100 feet away. The logging circuit will be inside the house.
If so, put it on the shelf for a couple of months, buy an Arduino Uno and a few components such as LEDs resistors and work through the examples that come with the Arduino IDE first.
