Advice on cables and interfacing to the arduino
I am currently building a home made weather station. Initial testing is complete and all sensors are working correctly indoors with short cables. The next step is to mount the sensors outside and I am looking for a little advice as to what type of cabling I should use and any general advice that I should be aware of.
Basically my station consists of the following:
Wind anemometer - Inspeed Vortex which produces 3V pulses which are counted by a micro
WInd Vane - Inspeed E-vane which produces a voltage between .25V and 4.75V depending on direction
DS18B20 temp sensor
SHT15 humidity sensor
SCP1000 pressure sensor
Hobby boards (rainwise) rainfall gauge
All of the above sensors are connected to an arduino duemilnova.
Anyway the anemometer and wind vane come with "exterior grade" cable which does seems quite slim. It consists of two/three stranded wires which are not twisted or shielded. It also says that the cables are not terminated. I am not sure if I should replace these cables? with something stronger as part of the cable will have to go outside. Also as regards the termination, would there be any need to do anything? Does the arduino tale care of this? what problems could arise?
The same applies for the rainfall gauge, it has a light cable which i am not sure if I should replace. (I did read something in Tom Bitsons book weather toys which I saw snippets on google books where he said that the cable should be replaced or potential problems could arsie, but he did not say what the problems may be). I would be grateful if someone could fill me in on the details of what issues could arise (if any) if the cable was not replaced and also what options (cable types) and advantages there would be if the cable was changed.
For the temperature and humidity humidity sensors I am planning on using cat5 cable, which from reading on the web seems to be the norm. But is it ok to run cat5 cable outdoors?
One final question, since I have some sensors which use a digital interface and other which are purely analog, would anyone see any potential problems when all sensors are mounted outside and connected to the arduino. I am thinking of signal integrity issues etc. Are there any precautions I should have in mind?
Also can anyone give me some advice on connecting the actual cables to the arduino pins. My plan is to solder the wire onto a small pin and connect the stick the pin into the arduino pin socket. Would there be any issue with this approach?
Many thanks for the advice.
Yea, that can be a little unreliable depending on wire size/stiffness and pin fit to the socket pin. A lot of us utilize male header strips that you can cut to your needed connector length and solder the wires to the needed pin, the extra unconnected pins add some stablity to the connection. Here is one source for the male headers:
Lefty
