Advice on Creating a Negative Voltage Supply
Hi everyone! I am currently working on a project that requires me to generate a negative voltage supply from 0 V to approximately -1.1 V and have that ideally oscillate from 0 to -1.1 V using an Arduino. I was looking at how to best proceed. From looking at the previous threads, I saw that it was not possible to do this via the microcontroller as it can only produce 0 to +5 V. I saw a guide on producing a negative power supply using a 555 timer on all about circuits and attempted the set up using a pwm pin and varying the output with a for loop that would increment gradually from 0 V to 1.1 V using the AnalogWrite command. It did not invert the voltage from 0 to -1.1V, and I got noisy variable negative output when using a multimeter to test.
Is there a way I could vary and oscillate the voltage from 0 to -1.1V? If not, would using the 5 V pin in conjunction with a digital potentiometer to change the voltage output from 0 to -1.1 V be a more feasible option to pursue?
Any help or recommendations would be greatly appreciated. Thank you for your help!
See Creating negative Voltage with Arduino Mega 2560 - Introductory Tutorials - Arduino Forum
Adapt for your particular Arduino.
You don't say what the current requirement is from this negative supply.
Oscillation from 0 to -1.1V is the same as +2V to +0.9V - it just depends on your ground reference. This does smell a bit like an XY problem.
What is your application? Why do you think you need this negative voltage? What is the nature of this desired "oscillation" - waveform, frequency?
An Arduino does not have a DAC but there are ways to create specific voltages, including below the negative and above the positive supply (aka GND and Vcc).
Please explain your project. There may be no need for a negative voltage supply.
But your understanding here is also not correct:
Try this link: https://www.allaboutcircuits.com/projects/build-your-own-negative-voltage-generator/
You will find it and an explanation of how it works. You can use one of the PWM pins for the clock, If you need more power you can use a buffer to drive it. This response is to help you get started in solving your problem, not solve it for you.
Good Luck & Have Fun!
Gil
