Hi all! I'm new to Arduino, but not new to embedded systems development. For the past 22 years I've been a corporate software engineer then a manager of software engineers. Before that, going back around 30 years, I was an embedded systems engineer that developed custom firmware in C, assembler, and ladder. I've dabbled in electronics as a hobby all my life, and my passion has always been the low-level stuff, but my formal education and training and most of my career has been on the corporate software development side. Anyway, I say all that just to establish my bonafides on the development side...
As to Arduino and modern turnkey microcontrollers, I'm a newbie. I've got a project idea in mind and wanted to run it by some of you experts to hopefully get some guidance.
There exists devices, like this one, designed to monitor safes that report up to a remote server on a regular basis with things like door openings, temperature, humidity, motion, vibration, internet connection, etc. You can then set thresholds on the server to generate alerts via SMS or email.
While $200 isn't extraordinarily expensive, especially compared to the cost of the safe and its contents, I thought this would be a fun project to replicate and possibly improve upon with a microcontroller and some sensors. So it's not so much about saving money (although that's probably possible not counting my time), it's more of an excuse to tinker around and build something customized.
So, with that in mind, I'm looking at something like an Arduino and/or ESP8266 that can connect to my WiFi network and report its status via a REST interface to a remote server. If it hasn't reported in within a set interval, then the server can generate an alert that the internet is down/cut, in addition to alerts when any of the sensor thresholds are reached.
I'm considering the following as far as inputs/sensors go:
- Temperature
- Humidity
- Door opening (from photocell or IR motion detector, or both)
- Vibration (both high frequency, such as someone drilling the safe, and low frequency pounding/banging)
- Motion (like sliding or tipping the safe)
- Water level
- Support for external Wifi antenna (inside a safe isn't the most wifi friendly atmosphere)
- Support for powering up/down a 12v LED light strip on door open/close.
And ultimately all packaged in a neat plastic box. The safe has a power outlet so power is available, although running it on battery (or battery backup) would be preferable in case power is cut. And before you ask, no this isn't the only security system around the safe. It's more of a hidden backup system that can also alert on things other than burglary attempts.
I'm up for coding the logic on the controller to monitor the inputs and report to the remote server, which I'll also code. I'm thinking I'd like the remote server to also act as a configuration panel, so it can push a configuration back down to the device for adjusting things like thresholds.
What I'm not sure of is which microcontroller approach to take. This seems overkill for a full blown computer like a Raspberry Pi, which I'd also have to keep cool. I was thinking an UNO 3 but after discovering the ESP8266 it seems I could actually run the logic there and have wifi to boot... but it's short on inputs. And is it even possible to wire up an external antenna jack on the ESP8266?
So, that's my long-winded intro and appeal for guidance, or to just tell me I'm crazy and buy the $200 device that's made for this. But where's the fun in that? ![]()
Thanks for any advice!
David
