Hi all
I have an upcoming project, and I wish to use Mosfets... something I don't tinker with very often.
The requirements will be for a Pro-mini or similar to control pairs of outputs at +24v 4A.
Here is the twist. These outputs need to isolate from the supply entirely when off, so a P-Channel for the +24v and an N-Channel for the 0v.
Now in an ideal world, these outputs would have the ability to be reversed, but I'll try to walk before running.
Try as I might, I have real issues trying to understand how you calculate this stuff.
I found this image of a P-channel. Suitable? (fills me with fear having the +12v rail on the 5v pin - yes, keep the grounds apart).
I actually like the idea of isolating the Arduino using opto-couplers. I have loads of those lying around
As for the Mosfets themselves.... apart from literally every item in RS/Farnell and Digikey being out of stock, I found these..
https://uk.rs-online.com/web/p/mosfets/6710949
https://uk.rs-online.com/web/p/mosfets/6710936
But... with 2434 to choose from after narrowing down some of the specs... where the heck do you start!
I could achieve it with relays, but that is expensive, unwieldy and noisy.
Any pointers would be oh so very gratefully received.
