I have two nano boards and want to send a number from one board using the keypad, to another board which will then display the number on a seven segment display.
I have written the code but I seem to have two problems
#1 I dont know how to wire the set up so that the second board can read the values correctly? can i use any pin or are there set serial pins to use for Serial.available() and Serial.read()?
#2 is there a better way to turn a char to an int? other than just setting each umber char as an interger in seperate lines of code? thanks for the help.
This is my code.
/////////////////////////////////////seven segment/////////////////////////////////////////////////////////
{ if (Serial.available()) //sends to other board
byteRead = Serial.read(); //reads value
reply = 1;
for (int ia = 1; ia<=9; ia++)
digitalWrite(pinArray[ia-1], SevenSegmentMap[byteRead][ia-1]);
Serial.write(reply);
reply = 0;
//////////////////////////////////////keypad//////////////////////////////////////////////////
char key =kpd.getKey();
if (key != NO_KEY)
Serial.println(key);
if(key == '0')
number = 0;
else if(key == '1')
number = 1;
else if(key == '2')
number = 2;
else if(key == '3')
number = 3;
else if(key == '4')
number = 4;
else if(key == '5')
number = 5;
else if(key == '6')
number = 6;
else if(key == '7')
number = 7;
else if(key == '8')
number = 8;
else if(key == '9')
number = 9;
for (int ib = 1; ib<=9; ib++)
digitalWrite(pinArray[ib-1], SevenSegmentMap[number][ib-1]);
Serial.write(number);
Serial.println(number);
if(Serial.available())
if (byteRead != 0)
digitalWrite(ledpin, HIGH);
digitalWrite(ledpin, LOW);
