Advice on serial communication library
Greetings all,
I've just released my first Arduino-specific library, SerialUI. I use it to provide user interfaces (menus, sub-menus and commands) for my Arduino projects, through the serial line. It provides built-in functions like menu hierarchy navigation and on-line help.
You can find details and documentation at SerialUI – Inductive-Kickback.com. If you're interested in this type of functionality, or in Arduino libraries in general, I'd appreciate any comments, questions and/or feedback.
This is the first release, so it may still have some rough edges. Also, it uses dynamic memory allocation and the HardwareSerial, making it kinda heavy (a simple test program will compile around 7k). I'm working on some config flags that will allow you to sacrifice a little flexibility and RAM for savings on the flash size side. Anything else that might be useful or of interest?
Thanks,
PatD
A few remarks:
  • The example file is SuperBlinker.pde, maybe SuperBlinker.ino is better.
  • The example uses a baudrate ot 115200, perhaps the default of 9600 is better.
  • I need to set CR + LF or LF in the serial monitor to see the menu. Only the CR doesn't work. You have that well documented, but I think it should work in all situations.
  • Do you use real tabs for indent ? I would prefer 2 or 4 spaces.
  • At 9600 baud, there is a timing issue. The received command is handled, but not the whole command is received yet.
Hi Erdin, thanks for your reply.
Ah, hadn't noticed this (new?) convention... not sure what the difference is, will look it up and adjust.
Yeah, makes sense.
The problem here is Serial.readBytesUntil(), which expects a single char--so there's no way to use it with CR+LF in any case... guess I could just hand-roll the functionality and use a peek() if I hit a CR.
Guess so (Eclipse default). I've always preferred tabs for indentation, personally... what's the rationale for spaces?
I was unable to reproduce this @ 9600 baud--were you using the "SuperBlinker" example (which explicitly uses setTimeout()) or the simple example from the usage page?
Thanks again!
Regards,
PatD
To be able to handle CR or LF or CRLF, you can use the fact that CRLF is always in that order.
You could test for CR or LF and assume that both are end of line.
If it is CR, set a flag to ignore a following LF.
Any other character resets the flag.
Tabs or spaces? I'm a 'spaces'-man. I don't know why.
I used the SuperBlinker example. I didn't know there was a specific timeout.
Ok, I created a new readBytesToEOL() that handles all standard line-terminations. It's setup to block when called, until the EOL or max length is read, so it deals with the issue of the slow baud connections too.
Downside is that it'll block forever if there's no input, unlike readBytesUntil()... I'm not certain how much of a problem that is. Also set the example default to 9600 baud.
Anyhow 1.1 is up now at Download – Inductive-Kickback.com, if you want to play with it.
Thanks again for your input.
I didn't look into the code. I just run the example.
The settings command was split into, but I was not able to repeat it. So I scrolled back and dump that part here:
+++ Welcome to the SuperBlinker +++
Enter '?' to list available options.
*** Help for: SuperBlinker Main Menu
	information         Retrieve data and current settings
	enable              Enable/disable device
	settings            Perform setup and config
	quit                Exit SerialUI
	?                   List available menu items
	quit                Exit SerialUI
	quit                Exit SerialUI
	quit                Exit SerialUI
> information
(Called 'show_info' from menu: SuperBlinker Main Menu)
ID:
Color--> R:0 G:0 B:0
Device is OFF
> INFORMATION
ERROR Unknown selection: INFORMATION
Enter '?' for available options
> enable
enable
> sett
ERROR Unknown selection: sett
> ings
ERROR Unknown selection: ings
The issue was that you were actually in the "enable" submenu. I've made changes to the library
  • to provide clearer error reporting for instances like this,
  • to avoid breaking up commands into tiny slices, at the cost of a bit of RAM, and
  • to provide clues as to whether the menu item is a command or sub-menu
Thanks again for your input :slight_smile:
Regards,
PatD
