A newbie here, We are building a "fast" line follower and We are using this 6V 500rpm jga12-n20 motor.
I am wondering which motor driver should we use that is most compatible for that motor, I've seen people use l298n and l293 motor driver but I don't know if which should we use or if there are other options available.
I am also wondering if the bump sensor in the 5 channel array IR sensor will affect the feedback making it slow, or can I adjust it in the code.
I have almost no experience with motors, but in the forum they do not recommend L293 and L298 drivers because there was a big loss of power in the driver itself. Since you will not reverse the motors, you can only control them with a MOSFET transistor - for example SI2300 or IRLML2502.
