Advice on Struct command
Hi All
This piece of code forms part of a program I have copied that sends data over Wi-Fi.
I am trying to change it for my own purposes.
Firstly I wanted to change the struct to my own variables and names, but I don’t fully understand the code.
Could somebody please explain this bit:-
struct led_command send_data;
send_data.opmode = op_mode;
send_data.data = data;
I don’t understand why there is 2 lots of names after the struct command.
or where send_data.opmode or send_data.data come from as names/declarations.
void sendLedData(uint32_t data, uint8_t op_mode)
 for (int i = 0; i < NUMBER_OF_CLIENTS; i++)
    IPAddress ip(192,168,4,2 + i);
    UDP.beginPacket(ip, 7001);
    UDP.write((char*)&send_data,sizeof(struct led_command));
    UDP.endPacket();
Blue407:
I don't understand why there is 2 lots of names after the struct command.
They come from the declaration of the struct which is in the code that you did not include in your post.
You have only posted a snippet. We cannot see the information you have hidden from us.
Somewhere in the other code there is a definition of led_command, possibly as a type declaration that includes opmode and data.
Thats what I was missing, thanks.
I didn't see that bit, so hadn't changed the definition before I changed the code.
Thanks!
