Advice please on how to hook this fuel sender to Arduino ?
Gyus,
I have one of these fuel senders in my car and want to hook it up to my Arduino - on page 3 of this PDF it explains how it works - i have verified correct operation with an Ohmmeter - just wondering what the physical connection to the Arduino would look like (the gauge that i got with this is dead and rather than buy another i thought i could interface it to a Mega that i was going to install into the car)
http://www.dakotadigital.com/pdf/sen-06-1.pdf
Craig
How about making it one arm of a voltage divider and reading the voltage at the centre point on an analog pin?
Henry_Best: How about making it one arm of a voltage divider and reading the voltage at the centre point on an analog pin?
OK i will give that a try and see what i get back - thanks
Craig
It should be no different than reading a pot. The only difference is that the fuel level adjusts the resistance, not your hand.
Henry_Best: It should be no different than reading a pot. The only difference is that the fuel level adjusts the resistance, not your hand.
Thanks will let you know after the weekend how it went
Craig
