This is an old video of my setup. Fuses, disconnects have been added, the solar panels have been rewired and reinforced and a grounding rod has been attached to panels and all equipment. The little 400 watt modified syne wave inverter has been upgraded to a more reliable/ higher wattage inverter. The grid tied inverter is the same as the video though. Im posting this just to satisfy all the people choosing to judge me rather than help me.
As you can see, no equipment has been modified and everything works the way they were designed to work.
The inverter can be found at https://www.amazon.com/gp/aw/d/B00RWYXVC6/ref=mp_s_a_1_2?ie=UTF8&qid=1471724173&sr=8-2&pi=SY200_QL40&keywords=500+watt+grid+tie+inverter&dpPl=1&dpID=51Qm2b0ylsL&ref=plSrch
The timer on the wall turns on and off which cuts grid power to the sensor in the inverter. When the inverter senses there is no grid power it shuts down as a safety mechanism.
Instead of using a just a timer, i would like to also set up a way to turn on and off the inverter based on battery voltage.
By adding a relay to either the dc wire or the ac wire, when it disconnects power, the inverter will shut down.
My thought is to do it from the ac side since there is less current, but i could do it from the dc side if it makes you sleep better at nite.
I just ordered an arduino kit which will arrive monday. I would like to learn the arduino for many different projects in the future. The solar automation project just seemed the easiest to build for learning the arduino.
I came here asking for guidance on the arduino integration into my solar project. My thought being either i go at it blindly, or i ask for assistance. I chose the latter for safety reasons. I hobby with electronics and gadgets, but this is the first time I'll be building something myself rather than just buying something premanufactured. I could by a low voltage cutoff and it would do everything im needing it to do. But for hobby sake, i would like to attempt to build something myself which can be expanded on later.
As i become more familiar with arduino, eventually id like to build a quadcopter, home automation projects etc. But for now, i figure id stick to something less intricate and more "newbie level".
This seemed more newbie level:
Sense voltage, is it good? Activate relay. Is it bad? Deactivate relay.
So far, iv learned in the comments that there is an arduino sensor for 12v dc batteries. Does anyone know what the sensor is called and where to buy it?
Also any ideas on any sample sketches that may be helpful.
I take full responsibility and accept liability on my solar equipment. If you would like to judge me on my solar, or lecture me on solar laws, utility laws, etc, feel free to do so on my youtube video. If you would like to help guide me on my arduino project, please feel free to do so here.
Thank you
