Advice- Roller Blind Automation
Hello! This is my second arduino project so I’m still a Noob. I need help in deciding what products will achieve my goal of automating my blinds.
Here are my requirements…
  1. The zebra blinds are similar to roller blinds. They just need an up/down action. That said they need to be able to fine tune.
  2. I would prefer to control them with Alexa through voice commands but an iPhone app would also be okay.
  3. I would like a quiet motor if possible.
  4. There should be a safety stop on top and bottom travel but I don’t want sensors.
The blinds aren’t as heavy as regular Venetian blinds. I suppose I should measure how much force will be required to lift them. I’m not sure how to do that though.
Any help you guys have would be greatly appreciated!
![image|375x500](upload://pXk2y3r3KimxbeQ7tbGIChDWqFX.jpeg
I suggest that you Google "Roller Blind Automation arduino" to get some ideas from how others have done similar projects.
How does that work? Normally one would use switches like Hall effect, optical or mechanical. Or sense motor current. But all of those require sensors of some sort.
What power is available? Volts? Amps?
Hi! Thanks for the response! I’ve done research on this forum and I’m gathering bits of advice from different posts. But because my blinds are zebra blinds they are different in nature to roller blinds. They need more fine-tuning to adjust them. So I started my own post.
As for blind travel I know that the motor can have limits on revolutions. Maybe that’s why I won’t need sensors? Again, just looking for someone to clarify.
It takes feedback of some sort for the motor to know its position unless you have physical stops. For some motors that can work, low power steppers in automotive gauges home themselves that way, but you have to know that the motor can be stalled without hurting it or it mechanical system.
The first thing to figure out is how much torque the motor will need. Then, along with other requirements*, you can choose the specific motor. So you could end up with a stepper motor or DC motor with a gearbox or worm drive.
Next choose a driver that will handle the specific motor.
Then choose a power supply.
*Speed, must the position be held without power, does it need to do precise positioning, etc.
Okay, great! Thank you. This is a start. I appreciate your help!
