Advice with a RFID project
Hello Guys,
I am learning to use the Arduino and hoping to make an RFID user system. I have been working on a little of the code (mainly looking at examples). Looking to know if there are any tutorials that would be useful for completing this project.
Here are the stages I see:
1) Make the RFID scanner print data (done using example code)
2) Make the Screen work in prototype mode (done using example code)
3) Make screen and RFID sensor run side by side (done mixing code of above 2)
4) Get data from card and store as variable (not working)
5) Compare data from card with variable (not done)
4) Store data in the EPROM (for users of cards) (not done)
5) Print out which user card is assigned to.
6) Store details of access history in EPROM.
7) Install ethernet sheild ( not done)
8) Export access details online as JSON (not done)
I will post the code causing issues in another thread but just wanted to know if there are any specific tutorials that my be best to follow related to this project.
Note: I'm new to Arduino but have years of coding experience in PHP and other OOP languages (yes I consider PHP OOP!). So don't need to learn too much about arrays and operators and things like that just specific Arduino "Quirks" if there are some.
Cheers guys.
JSON library for Arduino: GitHub - interactive-matter/aJson: aJson is an Arduino library to enable JSON processing with Arduino. It easily enables you to decode, create, manipulate and encode JSON directly from and to data structures.
I'm workinig in temperature sensor with web server to see charts. I think write logs on SD card in json format.
Lago:
Perfect, thanks Lago this is just the sort of thing I am looking for. How come you say write these to SD? I was considering just pushing them to some server with an Ethernet shield installed on the Arduino?
