Advice with LLAP code
I am using a ciseco xinoRF to control a pc fan using a dallas temp sensor.
I have been having problems with the code in that it does not send the Starting Message or temp.
When I remove the code for the fan it works ok but as soon as I put it back in it stops.
I am getting a bit frustrated and think I must be missing something fundamental.
Thank you
// Do not remove the include below
#include "LLAPav.h"
#include <LLAPSerial.h>
#include <OneWire.h>
#include <DallasTemperature.h>
//The setup function is called once at startup of the sketch
/*LLAP AV
 * Aim to control fan in av cabenet depending on temp
 * Upload to LLAP
 * Enable manual overide Possiible
#define ONE_WIRE_BUS 9 //Temp input pin
#define TEMPERATURE_PRECISION 9
#define FanOutputPin 3 //Fan Output Pin
#define DEVICEID "AV"	// this is the LLAP device ID
// Setup Temp Sensor
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
unsigned long lastmillis = 0;
unsigned long llapmillis = 0;
char TempString[10];
char RPMString[10];
double Input = 0;
double minTemp = 20;
// inputs
uint8_t inputs[] = {2,3,4,7,10,12,254};
String msg;        // storage for incoming message
String reply;    // storage for reply
	//Start LLAP
	  	LLAP.init(DEVICEID);
		pinMode(8,OUTPUT);		// switch on the radio
		digitalWrite(8,HIGH);
		pinMode(4,OUTPUT);		// switch on the radio
		digitalWrite(4,LOW);	// ensure the radio is not sleeping
		delay(400);				// allow the radio to startup
		 byte i=0;
		  while (inputs[i] != 254) {pinMode(inputs[i],INPUT); digitalWrite(inputs[i++],HIGH);}
		  i=0;
		  String permittedChars = "-#@?\\*ABCDEFGHIJKLMNOPQRSTUVWXYZ";
	//Temp setup
		sensors.begin();
		sensors.requestTemperatures();
		Input = sensors.getTempCByIndex(0); //Set Input to Current Temperature
	 //Setup Pins
			pinMode(FanOutputPin, OUTPUT);
			LLAP.sendMessage(F("STARTED"));  // send the usual "started message
			digitalWrite(FanOutputPin, HIGH);
	//llap recieve
	if (LLAP.bMsgReceived) // got a message?
        msg = LLAP.sMessage;
        LLAP.bMsgReceived = false;
        reply = msg;
        if (msg.compareTo("HELLO----") == 0)
            ;    // just echo the message back
        else if (msg.startsWith("SETT"))
                    msg = msg.substring(5);
                    int value = msg.toInt();
                    minTemp = value;
                    reply = "TempSet-";
	//Read Temp
	if(millis() - lastmillis == 10000){
	Input=sensors.getTempCByIndex(0);
	if(Input<= minTemp){
	else{
		digitalWrite(FanOutputPin, LOW);
		lastmillis = millis();
//Need to add LLAP output
	   if(millis() - llapmillis == 60000){
		   if (isnan(Input)){
			LLAP.sendMessage(F("ERROR"));
			dtostrf(Input,5,2,TempString);
				String ST;
				ST = "T" + String(TempString);
		LLAP.sendMessage(ST);
		llapmillis = millis();
uint8_t inputs[] = {2, 3, 4, 7, 10, 12, 254};
Is the fan connected to pin 3 or is an input connected to pin 3 ?
Fan
I thought the
was part of the serial buffer for the LLAP receive.
Have I misunderstood what that line is for?
I am very new at this but having lots of fun.
Thank you
These lines set pin 3 to be an INPUT
  byte i = 0;
    pinMode(inputs[i], INPUT);
    digitalWrite(inputs[i++], HIGH);
These lines set pin 3 as an OUTPUT
The inputs array does not seem to be used in the program so I do not know what it is for.
Thank you.
I think it was a hang over from previous attempt. Will remove those lines later an give it a go.
