Hi!
Graynomad:
Ok, when I see a huge driver chip like that I assume large currents.
However If you think it's necessary, I can add it in.
Look at the on resistance, x that by 600mA to get the watts generated, x that by the C/W value that should be in the data sheet. That will tell you how many degrees above ambient the chip will run. Add that value to the expected ambient temp and if the result is over the max junction temp you will have problem.
Clear
Now the schematics I really don't understand. You seem to have GND from each pair going to a header (and from there I assume a motor). How do two GND lines control a motor?
The drawing has lines all over the place including through components, and as far as I can tell the pin names don't match those in the data sheet. For examples you have pin 2 as "EF", in the data sheet it's "IN". There is no EF on the chip unless we're looking at different data sheets. Can you post a link to the one you are using?
And the mess of resistors between the optos and the driver is indecipherable.
The purpose of a schematic is to make a design clear, this one does not do that I'm afraid.
Rob
Yes that is a different chip but it's the same package, (I can't find a library for the BTN7971b)
I attached the pdf in my first post, but here is the link :
http://goo.gl/vOsZpO
Sorry for my schematic, this is only my 3 rd pcb, I am still learning alot.
I will try and fix that In the morning,
Otherwise if you have any suggestions on the layout/circuit
or If you recommend I change any values of capacitors or resistors, please advise!
CrossRoads:
How does 12V get into the board? I don't see a connector for that.
This board will mount on top of a Mega? You can't supply motor power from the Mega - the Mega input connector is not rated for that much current, and neither is the header. Add one specifically for the board, and pass 12V to the Mega if you want just 1 power connector.
Yes I still need to add a connector for my battery, i know.
The mega will be mounted on the board, I am planing on powering the mega from the 12->5v converter and use that to give the motor IC's 5V power.
MarkT:
Those devices have a worst case Ron of 0.5 ohms (full temperature range), 0.2ohms
(typical for a cool device).
At their rated current of 5A they will be dissipating about ~ 10W each or so, so large
metal heatsink is mandatory. Up to about 1.3A they will survive without one I estimate.
Where did the 44A figure come from?
datasheet: http://goo.gl/vOsZpO
HS/LS Continuous Drain Current: Max: 44A
