adxl 345 output strane behavior
Hi
I am starting to try with ADXL345 with this sketch:
I2C comunication
 read acceleration value
 CS pin 3v3
 SDA pin SDA +10k to 3v3
 SDO pin GND
 SCL pin SCL +10k to 3v3
 3v3 VCC
 GND GND
#define _2g (4)
#define _4g (8)
#define _8g (16)
#define _16g (32)
#include <Wire.h>
#define DEVICE (0x53)    //ADXL345 device address
#define TO_READ (6)        //num of bytes we are going to read each time (two bytes for each axis)
#define samples (100)
float x1, y1, z1;
int sum_x, sum_y, sum_z;
int j;
byte buff[TO_READ] ;    //6 bytes buffer for saving data read from the device
int regAddress;
int x, y, z;
  Wire.begin();        // join i2c bus (address optional for master)
  Serial.begin(9600);  // start serial for output
  //Turning on the ADXL345
  writeTo(DEVICE, 0x31, 0b00001011);//0b00001011 self mode off with full resolution 16g
  writeTo(DEVICE, 0x2D, 0x08);
  writeTo(DEVICE, 0x2E, 0x80);
  regAddress = 0x32;    //first axis-acceleration-data register on the ADXL345
  int sum_x = 0;
  int sum_y = 0;
  int sum_z = 0;
 // readFrom(DEVICE, regAddress, TO_READ, buff); //read the acceleration data from the ADXL345
  //each axis reading comes in 10 bit resolution, ie 2 bytes.  Least Significat Byte first!!
  //thus we are converting both bytes in to one int
 /* x = (((int)buff[1]) << 8) | buff[0];
  y = (((int)buff[3]) << 8) | buff[2];
  z = (((int)buff[5]) << 8) | buff[4];
  for(j = 0; j < samples; j++)
    sum_x += x;
    sum_y += y;
    sum_z += z;
  x1 = sum_x / samples;
  y1 = sum_y / samples;
  z1 = sum_z / samples;
  sum_x = 0;
  sum_y = 0;
  sum_z = 0;
//  Serial.println("Start");
  Serial.print(x1, 2);
  Serial.print('\t');
  Serial.print(y1, 2);
  Serial.print('\t');
  Serial.print(z1, 2);
  Serial.print('\t');
  delay(20);//It appears that delay is needed in order not to clog the port
void writeTo(int device, byte address, byte val) {
  Wire.beginTransmission(device); //start transmission to device
  Wire.write(address);        // send register address
  Wire.write(val);        // send value to write
  Wire.endTransmission(); //end transmission
void readFrom(int device, byte address, int num, byte buff[]) {
  Wire.write(address);        //sends address to read from
    Wire.beginTransmission(device); //start transmission to device (initiate again)
  Wire.requestFrom(device, num);    // request 6 bytes from device
  int i = 0;
  while(Wire.available())    //device may send less than requested (abnormal)
    buff[i] = Wire.read(); // receive a byte
    i++;
if I define samples=100
I have this output:
-220.00	-268.00	140.00
-221.00	-267.00	139.00
-221.00	-268.00	140.00
-221.00	-268.00	139.00
-221.00	-267.00	141.00
-220.00	-268.00	139.00
-221.00	-268.00	141.00
I have this output:
-222.00	-269.00	796.00
-222.00	-270.00	794.00
-221.00	-269.00	796.00
-221.00	-267.00	793.00
-221.00	-270.00	794.00
-223.00	-267.00	796.00
-222.00	-269.00	794.00
-221.00	-268.00	795.00
-221.00	-270.00	795.00
someone can me explain that
Stefano
Hi stefa24
Try replacing this ...
... with this ...
long sum_x = 0;
long sum_y = 0;
long sum_z = 0;
I think you could be overflowing the integer variables when you add up 100 samples x 10-bit values.
In setup(), remove these duplicate declarations ...
int sum_x = 0;
int sum_y = 0;
int sum_z = 0;
Regards
Ray
Hi Hackscribble
Thanks, you have right, now it work fine.
Have you any experience with digital accelerometer?
Regards
Stefano
now it work fine.
Glad it worked :slight_smile:
Sorry, I have never used one :frowning:
