ADXL 345 reset
I'm want to use an ADXL 345 to measure angles. So far I got this part to work to measure the angle along a given axis.
Now is there a way to reset the measured angle to 0 and then display the angle again. I want to use it to measure the amount of throw of a control surface from a model airplane. When I place the sensor on the surface I want to reset it to 0 as this is the neutral position of the control surface. Then when moving the surface I need to get a reading again.
Ben
