ADXL345 and XBEE [Using I2C Wirelessly]
Hello! :)
  1. I am using ADXL345 [Accelerometer] with Arduino UNO.
  2. I am using I2C Protocol to get the data from the adxl345. Everything is working fine :)
Now I want to separate the adxl345 and Arduino board, i.e. I want to connect the adxl345 to a Xbee [both independently powered] & Arduino to another Xbee. I want to communicate through this Xbees.
I haven't tried but as far as I have researched I2C requires SCL & SDA i.e. it is synchronous & Xbees are Asynchronous [I guess for that matter all wireless data transfers are Asynchronous, correct me if I am wrong]. Also, ADXL345 supports only SPI & I2C to get the data. So how do I proceed?
Will an I2C to UART bridge work between ADXL345 & XBEE? If yes then will I be able to ask the ADXL345 to send data through Xbees using the Arduino board which is connected to another Xbee?
If not, please provide some solution [I don't want to introduce a Micro Processor on the ADXL345 side because I want that side to be a small as possible, since it will be a wearable device]
Thanking you all in advance :) :) :) :) :)
How are you planning to program the XBee to read the ADXL345? As manufactured and programmed by digi.com, the XBee does not have that capability.
True, but irrelevant.
You don't understand what an XBee is or can do, then.
You might as well say that chocolate ice cream is asynchronous.
With realistic expectations. That is, with some hardware in the picture that can do SPI or I2C. Like, oh, I don't know, maybe an Arduino.
You have a particular one in mind? How will you program it?
I suggest that you get over it. There are plenty of microcontroller devices that can do I2C and talk to an XBee that are tiny.
