ADXL345+Arduino Uno
I am trying to get x,y,z values from ADXL345 accelermeter connected to Arduino Uno.
I have connected the chip as follows:
VCC to 3.3V
GNG to GND
SCL to A5
SDA to A4
as per:
ADXL345 Hookup Guide - learn.sparkfun.com
I am using the code below for calibration:
as per:
Programming and Calibration | ADXL345 Digital Accelerometer | Adafruit Learning System
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_ADXL345_U.h>
/* Assign a unique ID to this sensor at the same time */
Adafruit_ADXL345_Unified accel = Adafruit_ADXL345_Unified(12345);
void displaySensorDetails(void)
  sensor_t sensor;
  accel.getSensor(&sensor);
  Serial.println("------------------------------------");
  Serial.print  ("Sensor:       "); Serial.println(sensor.name);
  Serial.print  ("Driver Ver:   "); Serial.println(sensor.version);
  Serial.print  ("Unique ID:    "); Serial.println(sensor.sensor_id);
  Serial.print  ("Max Value:    "); Serial.print(sensor.max_value); Serial.println(" m/s^2");
  Serial.print  ("Min Value:    "); Serial.print(sensor.min_value); Serial.println(" m/s^2");
  Serial.print  ("Resolution:   "); Serial.print(sensor.resolution); Serial.println(" m/s^2");
  Serial.println("");
void displayDataRate(void)
  Serial.print  ("Data Rate:    ");
  switch(accel.getDataRate())
    case ADXL345_DATARATE_3200_HZ:
      Serial.print  ("3200 ");
    case ADXL345_DATARATE_1600_HZ:
      Serial.print  ("1600 ");
    case ADXL345_DATARATE_800_HZ:
      Serial.print  ("800 ");
    case ADXL345_DATARATE_400_HZ:
      Serial.print  ("400 ");
    case ADXL345_DATARATE_200_HZ:
      Serial.print  ("200 ");
    case ADXL345_DATARATE_100_HZ:
      Serial.print  ("100 ");
    case ADXL345_DATARATE_50_HZ:
      Serial.print  ("50 ");
    case ADXL345_DATARATE_25_HZ:
      Serial.print  ("25 ");
    case ADXL345_DATARATE_12_5_HZ:
      Serial.print  ("12.5 ");
    case ADXL345_DATARATE_6_25HZ:
      Serial.print  ("6.25 ");
    case ADXL345_DATARATE_3_13_HZ:
      Serial.print  ("3.13 ");
    case ADXL345_DATARATE_1_56_HZ:
      Serial.print  ("1.56 ");
    case ADXL345_DATARATE_0_78_HZ:
      Serial.print  ("0.78 ");
    case ADXL345_DATARATE_0_39_HZ:
      Serial.print  ("0.39 ");
    case ADXL345_DATARATE_0_20_HZ:
      Serial.print  ("0.20 ");
    case ADXL345_DATARATE_0_10_HZ:
      Serial.print  ("0.10 ");
    default:
      Serial.print  ("???? ");
  Serial.println(" Hz");
void displayRange(void)
  Serial.print  ("Range:         +/- ");
  switch(accel.getRange())
    case ADXL345_RANGE_16_G:
      Serial.print  ("16 ");
    case ADXL345_RANGE_8_G:
      Serial.print  ("8 ");
    case ADXL345_RANGE_4_G:
      Serial.print  ("4 ");
    case ADXL345_RANGE_2_G:
      Serial.print  ("2 ");
    default:
      Serial.print  ("?? ");
  Serial.println(" g");
void setup(void)
#ifndef ESP8266
  while (!Serial); // for Leonardo/Micro/Zero
#endif
  Serial.println("Accelerometer Test"); Serial.println("");
  /* Initialise the sensor */
  if(!accel.begin())
    /* There was a problem detecting the ADXL345 ... check your connections */
    Serial.println("Ooops, no ADXL345 detected ... Check your wiring!");
    while(1);
  /* Set the range to whatever is appropriate for your project */
  accel.setRange(ADXL345_RANGE_16_G);
  // displaySetRange(ADXL345_RANGE_8_G);
  // displaySetRange(ADXL345_RANGE_4_G);
  // displaySetRange(ADXL345_RANGE_2_G);
  /* Display some basic information on this sensor */
  displaySensorDetails();
  /* Display additional settings (outside the scope of sensor_t) */
  displayDataRate();
  displayRange();
  Serial.println("");
void loop(void)
  /* Get a new sensor event */
  sensors_event_t event;
  accel.getEvent(&event);
  /* Display the results (acceleration is measured in m/s^2) */
  Serial.print("X: "); Serial.print(event.acceleration.x); Serial.print("  ");
  Serial.print("Y: "); Serial.print(event.acceleration.y); Serial.print("  ");
  Serial.print("Z: "); Serial.print(event.acceleration.z); Serial.print("  ");Serial.println("m/s^2 ");
I got the output as shown in the image attached.
This does not seem to be calibrated…
