Hello
I don't understand how to calibrate adxl345 to get z=1g
i try many code in internet any one can help me ?
my connection is i2c
vcc-->3.3v
GND-->GND
SDA-->A4
SCL-->A5
#include <ADXL345.h>
#include <Wire.h>
byte DEVICE_ADDRESS = 0x53; //This address is fixed for the board we use because pin 12 is fixed to GND
byte DATA_FORMAT = 0x31; //Data Format & Measurement Range Register
byte POWER_CTRL = 0x2D; //Power Control Register
byte INT_ENABLE = 0x2E; //Enable Data Ready Interrupt
byte OFSTX = 0x1E; //X_CALIB
byte OFSTY = 0x1F; //Y_CALIB
byte OFSTZ = 0x20; //Z_CALIB
byte DATAX0 = 0x32; //X-Axis Data 0
byte DATAX1 = 0x33; //X-Axis Data 1
byte DATAY0 = 0x34; //Y-Axis Data 0
byte DATAY1 = 0x35; //Y-Axis Data 1
byte DATAZ0 = 0x36; //Z-Axis Data 0
byte DATAZ1 = 0x37; //Z-Axis Data 1
byte values[6];
ADXL345 accel;
int x,y,z; //For storing the raw value
double xg, yg, zg; //For storing the G value
float x_bound[3] = {-9999, -9999, -9999}; //Upper, Lower, Middle
float y_bound[3] = {-9999, -9999, -9999}; //Upper, Lower, Middle
float z_bound[3] = {-9999, -9999, -9999}; //Upper, Lower, Middle
int calibrate = -1;
int CAL_DELAY = 400; //Calibration Delay - waiting time for user to make response
Wire.begin(); //Initiate the Wire library and join the I2C bus as a master. This is called only once.
//Minimum initialization sequance according to the application note.
writeRegister(DEVICE_ADDRESS, DATA_FORMAT, 0x0B); //Put the ADXL345 into Measurement Mode with full resolution (13-bit) and +/-16G range.
writeRegister(DEVICE_ADDRESS, POWER_CTRL, 0x08); //Start Measurement.
writeRegister(DEVICE_ADDRESS, INT_ENABLE, 0x80); //Enable Data Ready Interrupt.
pinMode(2, INPUT_PULLUP); //Pin2 (LOW) -> Calibration Mode, Pin2(HIGH, DEFAULT) -> Normal Mode
int calibration_mode = digitalRead(2);
if (calibration_mode == HIGH) {
// Serial.println("Normal Mode");
normalMode();
//Converting the raw accelerometer values to g's.
xg = x * 0.0039;
yg = y * 0.0039;
zg = z * 0.0039;
//Display the results
Serial.print(x, DEC);
Serial.print(", ");
Serial.print(y, DEC);
Serial.print(", ");
Serial.print(z, DEC);
Serial.print(" | ");
Serial.print(x_bound[0]);
Serial.print(", ");
Serial.print(x_bound[1]);
Serial.print(", ");
Serial.print(x_bound[2]);
Serial.print(y_bound[0]);
Serial.print(", ");
Serial.print(y_bound[1]);
Serial.print(", ");
Serial.print(y_bound[2]);
Serial.print(z_bound[0]);
Serial.print(", ");
Serial.print(z_bound[1]);
Serial.print(", ");
Serial.print(z_bound[2]);
Serial.print((float)xg, 2);
Serial.print("'g, ");
Serial.print((float)yg, 2);
Serial.print("g, ");
Serial.print((float)zg, 2);
Serial.println("g");
delay(4000);
if (calibration_mode == LOW) {
Serial.println("Calibration Mode");
if ((x_bound[0] == -9999) || (y_bound[0] == -9999) || (z_bound[0] == -9999)) {
Serial.println("Please release pin 2 from logic LOW position");
while (digitalRead(2) == LOW) {
//delay(CAL_DELAY);
calibrationMode();
else {
Serial.println("Module already calibrated. Do you want to calibrate again? (0 = No, 1 = Yes) ");
while (calibrate == -1) {
calibrate = Serial.read();
if (calibrate == '1') {
calibrationMode();
calibrate = -1;
else {
calibrate = -1;
void calibrationMode() {
//Get y-axis boundries
Serial.println("Place module to position 1 before count down reaches 0");
for (int i = 25; i >= 0; i--) {
Serial.println(i);
delay(CAL_DELAY);
for (int count = 1; count < 100; count++) {
normalMode();
y_bound[0] = y_bound[0] + y;
y_bound[0] = y_bound[0] / 100;
Serial.print("Y Low Bound = ");
Serial.println(y_bound[0]);
Serial.println("Place module to position 2 before count down reaches 0");
Serial.println(i);
delay(CAL_DELAY);
normalMode();
y_bound[1] = y_bound[1] + y;
y_bound[1] = y_bound[1] / 100;
Serial.print("Y High Bound = ");
Serial.println(y_bound[1]);
y_bound[2] = (y_bound[0] + y_bound[1]) / 2;
Serial.print("Y Mid Point = ");
Serial.println(y_bound[2]);
//Get x-axis boundries
Serial.println("Place module to position 3 before count down reaches 0");
Serial.println(i);
delay(CAL_DELAY);
normalMode();
x_bound[0] = x_bound[0] + x;
x_bound[0] = x_bound[0] / 100;
Serial.print("X Low Bound = ");
Serial.println(x_bound[0]);
Serial.println("Place module to position 4 before count down reaches 0");
Serial.println(i);
delay(CAL_DELAY);
normalMode();
x_bound[1] = x_bound[1] + x;
x_bound[1] = x_bound[1] / 100;
Serial.print("X High Bound = ");
Serial.println(x_bound[1]);
x_bound[2] = (x_bound[0] + x_bound[1]) / 2;
Serial.print("X Mid Point = ");
Serial.println(x_bound[2]);
//Get z-axis boundries
Serial.println("Place module to position 5 before count down reaches 0");
Serial.println(i);
delay(CAL_DELAY);
normalMode();
z_bound[0] = z_bound[0] + z;
z_bound[0] = z_bound[0] / 100;
Serial.print("Z Low Bound = ");
Serial.println(z_bound[0]);
Serial.println("Place module to position 6 before count down reaches 0");
Serial.println(i);
delay(CAL_DELAY);
normalMode();
z_bound[1] = z_bound[1] + z;
z_bound[1] = z_bound[1] / 100;
Serial.print("Z High Bound = ");
Serial.println(z_bound[1]);
z_bound[2] = (z_bound[0] + z_bound[1]) / 2;
Serial.print("Z Mid Point = ");
Serial.println(z_bound[2]);
void normalMode() {
readRegister(DEVICE_ADDRESS, DATAX0, 6, values);
//The ADXL345 gives 10-bit or 13-bit acceleration values, but they are stored as bytes (8-bits). To get the full value, two bytes must be combined for each axis.
//The X value is stored in values[0] and values[1].
x = ((int)values[1]<<8)|(int)values[0];
//The Y value is stored in values[2] and values[3].
y = ((int)values[3]<<8)|(int)values[2];
//The Z value is stored in values[4] and values[5].
z = ((int)values[5]<<8)|(int)values[4];
delay(15);
void writeRegister(byte device, byte registerAddress, byte value) {
Wire.beginTransmission(device); //Start transmission to device
Wire.write(registerAddress); //Specify the address of the register to be written to
Wire.write(value); //Send the value to be writen to the register
Wire.endTransmission(); //End transmission
void readRegister(byte device, byte registerAddress, int numBytes, byte *values) {
byte address = registerAddress;
Wire.write(address);
Wire.requestFrom(device, numBytes); //Request 6 bytes from device
int i = 0;
while (Wire.available() && i < numBytes) { //Device may send less than requested
values[i] = Wire.read(); //Receive a byte from device and put it into the buffer
i++;
