I made angle meter with ADXL345, measuring angle using X Axis.
In this example, as you can see, when angle is higher that desired, left or right LED is turning ON.
It is working perfect when I lean it to the "left" and "right" slowly, but when I'm shaking device "up" and "down" ( Y axis), LEDs are turning on also. So, I would like to remove this "side effect" ie to avoid impact of Y axis on my measurements.
Here is sample code that I used:
#include <Wire.h>
#include <ADXL345.h>
#include <EEPROM.h>
ADXL345 adxl;
int x, y, z;
int rawX, rawY, rawZ;
float X, Y, Z;
float rollDeg1;
int ledLeft = 3;
int ledRight = 4;
//int adress = 0;
adxl.powerOn();
pinMode (ledLeft, OUTPUT);
pinMode (ledRight, OUTPUT);
adxl.readAccel(&x, &y, &z);
rawX = x - 7;
rawY = y - 6;
rawZ = z + 10;
X = rawX / 256.00;
// Y = rawY / 256.00;
// Z = rawZ / 256.00;
rollDeg1 = 180 * (atan(Y / sqrt(X * X + Z * Z))) / PI;
if (rollDeg1 >= 45) {
digitalWrite (ledRight, HIGH);
delay(50);
digitalWrite (ledRight, LOW);
if (rollDeg1 <= -45) {
digitalWrite (ledLeft, HIGH);
delay(50);
digitalWrite (ledLeft, LOW);
Thanks in advance.
