ADXL345 weird output
Hey forum,
I have an ADXL345 accelerometer (I2C communication). On a flat surface, the raw values should be close to 0,0,250 for x,y,z axes respectively. The raw values it gives me though seem to be floating (a lot) around those above. Here are some of the readings:
-63 | 48 | 238
-75 | 24 | 333
-65 | 28 | 232
11 | 31 | 267
9 | 35 | 249
-15 | 21 | 259
-35 | 35 | 244
-62 | 11 | 282
-41 | 25 | 249
I want to confirm that there is something wrong with this accelerometer.
maybe this http://forum.arduino.cc/index.php/topic,101845.0.html could help you.
Thanks for the reply.
However, the problem described in the forum is not the same as mine. With my unit, the difference between readings is huge (sometimes its around 100), in other words, the readings don't remain relatively constant.
Can't see any code or schematic.
I am sure it is not the code.
I've tried countless ADXL345 libraries, all of which produce the same results. Here is the included example of one of those libraries:
// I2C device class (I2Cdev) demonstration Arduino sketch for ADXL345 class
// 10/7/2011 by Jeff Rowberg <jeff@rowberg.net>
// Updates should (hopefully) always be available at https://github.com/jrowberg/i2cdevlib
// Changelog:
//     2011-10-07 - initial release
I2Cdev device library code is placed under the MIT license
Copyright (c) 2011 Jeff Rowberg
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files (the "Software"), to deal
in the Software without restriction, including without limitation the rights
to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
copies of the Software, and to permit persons to whom the Software is
furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in
all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
THE SOFTWARE.
// Arduino Wire library is required if I2Cdev I2CDEV_ARDUINO_WIRE implementation
// is used in I2Cdev.h
#include "Wire.h"
// I2Cdev and ADXL345 must be installed as libraries, or else the .cpp/.h files
// for both classes must be in the include path of your project
#include "I2Cdev.h"
#include "ADXL345.h"
// class default I2C address is 0x53
// specific I2C addresses may be passed as a parameter here
// ALT low = 0x53 (default for SparkFun 6DOF board)
// ALT high = 0x1D
ADXL345 accel;
int16_t ax, ay, az;
#define LED_PIN 13 // (Arduino is 13, Teensy is 6)
bool blinkState = false;
    // join I2C bus (I2Cdev library doesn't do this automatically)
    Wire.begin();
    // initialize serial communication
    // (38400 chosen because it works as well at 8MHz as it does at 16MHz, but
    // it's really up to you depending on your project)
    Serial.begin(38400);
    // initialize device
    Serial.println("Initializing I2C devices...");
    accel.initialize();
    // verify connection
    Serial.println("Testing device connections...");
    Serial.println(accel.testConnection() ? "ADXL345 connection successful" : "ADXL345 connection failed");
    // configure LED for output
    pinMode(LED_PIN, OUTPUT);
    // read raw accel measurements from device
    accel.getAcceleration(&ax, &ay, &az);
    // display tab-separated accel x/y/z values
    Serial.print("accel:\t");
    Serial.print(ax); Serial.print("\t");
    Serial.print(ay); Serial.print("\t");
    Serial.println(az);
    // blink LED to indicate activity
    blinkState = !blinkState;
    digitalWrite(LED_PIN, blinkState);
and its outputs:
accel:	108	-56	273
accel:	108	-56	273
accel:	24	54	303
accel:	24	54	303
accel:	21	-21	294
accel:	21	-21	294
accel:	146	-28	296
accel:	146	-28	296
accel:	2	84	253
accel:	2	84	253
accel:	2	84	253
accel:	17	20	278
As i said before, the readings should be close to 0,0,250 (250 equals 1g, the x,y,z should read 0g, 0g, 1g respectively)
ADXL345.h (12.6 KB)
ADXL345.cpp (60.9 KB)
