Hello,
I am trying run the adxl345 with esp8266 using thingspeak cloud. but i got error that "Error compiling for board Arduino Uno" & " ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]".
please help !
Here is the code
#include <SoftwareSerial.h>
#include <Wire.h>
//#include <Wire.h>
#define RX 2
#define TX 3
int getSensorData();
int ADXL345 = 0x53;
int X_out, Y_out, Z_out;
int countTrueCommand;
int countTimeCommand;
boolean found = false;
int valSensor = 1;
int sendCommand();
String AP = "High Voltage Lab"; // AP NAME
String PASS = "profnkroy"; // AP PASSWORD
String API = "ERK34DSVQ9XJGLO2"; // Write API KEY
String HOST = "api.thingspeak.com";
String PORT = "80";
String field1 = "field1";
String field2 = "field2";
String field3 ="field3";
//int X_OUT,Y_OUT,Z_OUT;
SoftwareSerial esp8266(RX,TX);
esp8266.begin(115200);
Wire.begin();
sendCommand("AT",5,"OK");
sendCommand("AT+CWMODE=1",5,"OK");
sendCommand("AT+CWJAP=\""+ AP +"\",\""+ PASS +"\"",20,"OK");
Serial.println("date&time,x_out,y_out,z_out");
Wire.beginTransmission(ADXL345);
Wire.write(0x2D); //talk to POWER_CTL Register - 0x2D
Wire.write(8); // Bit D3 High for measuring enable (8dec -> 0000 1000 binary)
Wire.endTransmission();
delay(10);
valSensor = getSensorData();
String getData = "GET /update?api_key="+ API +"&field1="+valSensor+"&field2="+valSensor+"&field3="+valSensor;// field +"="+String(valSensor);//CHANGE
sendCommand("AT+CIPMUX=1",5,"OK");
sendCommand("AT+CIPSTART=0,\"TCP\",\""+ HOST +"\","+ PORT,15,"OK");
sendCommand("AT+CIPSEND=0," +String(getData.length()+4),4,">");
esp8266.println(getData);delay(1500);countTrueCommand++;
sendCommand("AT+CIPCLOSE=0",5,"OK");
Wire.write(0x32);
Wire.endTransmission(false);
Wire.requestFrom(ADXL345, 6, true);
X_out = ( Wire.read() | Wire.read() << 8);
Y_out = ( Wire.read() | Wire.read() << 8);
Z_out = ( Wire.read() | Wire.read() << 8);
Serial.print(",");
Serial.print(X_out);
Serial.print(",");
Serial.print(Y_out);
Serial.print(",");
Serial.println(Z_out);
delay(0.00000001);
// return random(1000); // Replace with your own sensor code
void sendCommand(String command, int maxTime, char readReplay[]) {
Serial.print(countTrueCommand);
Serial.print(". at command => ");
Serial.print(command);
Serial.print(" ");
while(countTimeCommand < (maxTime*1))
esp8266.println(command);//at+cipsend
if(esp8266.find(readReplay))//ok
found = true;
countTimeCommand++;
if(found == true)
Serial.println("OYI");
countTrueCommand++;
countTimeCommand = 0;
if(found == false)
Serial.println("Fail");
countTrueCommand = 0;
found = false;
here is error message:
C:\Users\DELL\Documents\program@ard\Revised_ESP_ADXL\Revised_ESP_ADXL.ino: In function 'void setup()':
C:\Users\DELL\Documents\program@ard\Revised_ESP_ADXL\Revised_ESP_ADXL.ino:30:26: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
C:\Users\DELL\Documents\program@ard\Revised_ESP_ADXL\Revised_ESP_ADXL.ino:31:35: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
C:\Users\DELL\Documents\program@ard\Revised_ESP_ADXL\Revised_ESP_ADXL.ino:32:61: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
C:\Users\DELL\Documents\program@ard\Revised_ESP_ADXL\Revised_ESP_ADXL.ino: In function 'void loop()':
C:\Users\DELL\Documents\program@ard\Revised_ESP_ADXL\Revised_ESP_ADXL.ino:45:33: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
C:\Users\DELL\Documents\program@ard\Revised_ESP_ADXL\Revised_ESP_ADXL.ino:46:66: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
C:\Users\DELL\Documents\program@ard\Revised_ESP_ADXL\Revised_ESP_ADXL.ino:47:62: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
C:\Users\DELL\Documents\program@ard\Revised_ESP_ADXL\Revised_ESP_ADXL.ino:49:35: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
C:\Users\DELL\AppData\Local\Temp\ccGq0fs3.ltrans0.ltrans.o: In function `loop':
C:\Users\DELL\Documents\program@ard\Revised_ESP_ADXL/Revised_ESP_ADXL.ino:43: undefined reference to `getSensorData()'
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino Uno.
