ADXL345 with SPI and SD Card - problem
Hello,
I saw many topics like mine but I did not find answer, so…
I have:
I need to connect SD Card and ADXL345 by SPI. I know that SPI Mode for SD Card is 0 and for ADXL345 is 3. I tried to write some data to ADXL register but nothing happen.
My sketch
#include <SPI.h>
#include <SD.h>
#include <ADXL345.h>
ADXL345 adxl;
int x;
volatile int resultx, resulty, resultz;
void writeRegister(byte reg, byte value)
  digitalWrite(10, LOW);
  SPI.transfer(reg);
  SPI.transfer(value);
  digitalWrite(10, HIGH);
  delay(5);
void readRegister()
  while(x>0)
    int buff[5];
    SPI.setDataMode(SPI_MODE3); // CPOL - 1  CPHA - 1  OUTPUT EDGE - FALLING  DATA CAPTURE - RISING
    SPI.transfer(ADXL345_DATAX0 | 0xC0);
    for(int i=0;i<=5;i++)
      buff[i]=SPI.transfer(0x00);
    resultx = word(buff[1], buff[0]);
    resulty = word(buff[3], buff[2]);
    resultz = word(buff[5], buff[4]);
    Serial.print("x: ");
    Serial.println(resultx);
    //Serial.print("  y: ");
    //Serial.print(resulty);
    //Serial.print("  z: ");
    //Serial.println(resultz);
    x--;
void fifo()
  Serial.println("FIFO IS FULL!");
void readto()
  SPI.transfer(0x00| 0x08);
  x=SPI.transfer(0x00);
  Serial.print(x, BIN);
  pinMode(8, OUTPUT);
  if (!SD.begin(8))
     Serial.println("SD CARD ERROR!");
  else Serial.println("SD CARD OK!");
  digitalWrite(8, HIGH);
  SPI.begin();
  writeRegister(ADXL345_BW_RATE, 0b00001001);
  writeRegister(ADXL345_INT_MAP, 0x01);
  writeRegister(ADXL345_DATA_FORMAT, 0x20);
  writeRegister(ADXL345_FIFO_CTL, 0b01010000);
  writeRegister(ADXL345_INT_ENABLE, 0x03);
  writeRegister(ADXL345_POWER_CTL, 0x08);
  readto();
The problem is that value of all registers are 0. It seems like it can’t write or read any value to/from register cause of SD Card. I can’t do it by I2C because my goal is to receive samples in high frequency.
Could you help me? What could be wrong? I attached circuit and results
Sorry, but circuit that I made is wrong.
Here is correct.
