Hello, I am working with adxl362 sensor, connected to Arduino Nano Board.
This is my code:
ADXL362_MotionActivatedSleep.ino for
Analog Devices ADXL362 - Micropower 3-axis accelerometer
go to http://www.analog.com/ADXL362 for datasheet
Arduino will "go to sleep" when circuit has been motionless for
a short period of time. Arduino will "wake-up" when moved.
License: CC BY-SA 3.0: Creative Commons Share-alike 3.0. Feel free
to use and abuse this code however you'd like. If you find it useful
please attribute, and SHARE-ALIKE!
Created June 2012
by Anne Mahaffey - hosted on http://annem.github.com/ADXL362
Connect SCLK, MISO, MOSI, and CSB of ADXL362 to
SCLK, MISO, MOSI, and DP 10 of Arduino
( See http://arduino.cc/en/Reference/SPI for details)
Connect INT1 of ADXL362 to DP2 of Arduino
( See http://arduino.cc/en/Reference/AttachInterrupt for details)
// Download LowPower library from http://github.com/rocketscream/Low-Power
#include <LowPower.h>
#include <SPI.h>
#include <ADXL362.h>
ADXL362 xl;
// Setup interrupt on Arduino
// See interrupt example at http://arduino.cc/en/Reference/AttachInterrupt
int16_t interruptPin = 3; //Setup ADXL362 interrupt output to Interrupt 0 (digital pin 2)
int16_t interruptStatus = 0;
int16_t XValue, YValue, ZValue, Temperature;
void setup(){
// Startup, soft reset
xl.begin(10); //soft reset
// Setup digital pin 7 for LED observation of awake/asleep
pinMode(7, OUTPUT);
digitalWrite(7, HIGH);
pinMode(10, OUTPUT);
digitalWrite(10,LOW);
// Setup Activity and Inactivity thresholds
// tweaking these values will effect the "responsiveness" and "delay" of the interrupt function
// my settings result in a very rapid, sensitive, on-off switch, with a 2 second delay to sleep when motion stops
xl.setupDCActivityInterrupt(300, 10); // 300 code activity threshold. With default ODR = 100Hz, time threshold of 10 results in 0.1 second time threshold
xl.setupDCInactivityInterrupt(80, 200); // 80 code inactivity threshold. With default ODR = 100Hz, time threshold of 30 results in 2 second time threshold
/* Other possible settings
// Motion activated On - stays on for 60 seconds
xl.setupDCInactivityInterrupt(80, 6000); // 80 code inactivity threshold. With default ODR = 100Hz, time threshold of 60000 results in 60 second time threshold
// Setup ADXL362 for proper autosleep mode
// Map Awake status to Interrupt 1
// *** create a function to map interrupts... coming soon
xl.SPIwriteOneRegister(0x2A, 0x40);
// Setup Activity/Inactivity register
xl.SPIwriteOneRegister(0x27, 0x3F); // Referenced Activity, Referenced Inactivity, Loop Mode
// turn on Autosleep bit
byte POWER_CTL_reg = xl.SPIreadOneRegister(0x2D);
POWER_CTL_reg = POWER_CTL_reg | (0x04); // turn on POWER_CTL[2] - Autosleep bit
xl.SPIwriteOneRegister(0x2D, POWER_CTL_reg);
// turn on Measure mode
xl.begin(10);
xl.beginMeasure(); // DO LAST! enable measurement mode
xl.checkAllControlRegs(); // check some setup conditions
delay(100);
// Setup interrupt function on Arduino
// IMPORTANT - Do this last in the setup, after you have fully configured ADXL.
// You don't want the Arduino to go to sleep before you're done with setup
pinMode(3, INPUT);
attachInterrupt(0, interruptFunction, RISING); // A high on output of ADXL interrupt means ADXL is awake, and wake up Arduino
void loop(){
// Check ADXL362 interrupt status to determine if it's asleep
interruptStatus = digitalRead(interruptPin);
// if ADXL362 is asleep, call LowPower.powerdown
if(interruptStatus == 0) {
Serial.print("\nADXL went to sleep - Put Arduino to sleep now \n");
digitalWrite(7, LOW); // Turn off LED as visual indicator of asleep
delay(100);
LowPower.powerDown(SLEEP_FOREVER, ADC_OFF, BOD_OFF);
// if ADXL362 is awake, report XYZT data to Serial Monitor
else{
// Serial.println("\nArduino is Awake! \n");
delay(100);
digitalWrite(7, HIGH); // Turn on LED as visual indicator of awake
xl.readXYZTData(XValue, YValue, ZValue, Temperature);
// give circuit time to settle after wakeup
delay(20);
// Function called if Arduino detects interrupt activity
// when rising edge detected on Arduino interrupt
void interruptFunction(){
I get all the output set to 0, also if the sensor is awake.
Could you help me?
