adxl3xx example in IDE
I've got a question about one of the examples in the IDE.
For the adxl3xx it has supply maximum voltage of 3.6V. However, in the IDE it says this
// Provide ground and power by using the analog inputs as normal // digital pins. This makes it possible to directly connect the // breakout board to the Arduino. If you use the normal 5V and // GND pins on the Arduino, you can remove these lines.
Is this example safe? It works but right now I refrain from using it for long periods.
Which ADXL3xx accelerometer do you have? The one that Sparkfun sells (http://www.sparkfun.com/commerce/product_info.php?products_id=849) has this on the data sheet:
Wide supply voltage range: 2.4 V to 5.25 V
I have the adxl335 at the sparkfun page it says
There is no on-board regulation, provided power should be between 1.8 and 3.6VDC.
It's likely i've damaged mine right?
You haven't done it any favors. It's not difficult to create a voltage divider, using 2 resistors so that the device can be powered by a digital pin.
pin (5V) --> R1 -+-> R2 --> gnd | adxl3xx
If R1 is ~3K and R2 is ~6K, the voltage to the adxl3xx will be ~3.67V. Make R1 a little larger or R2 a little smaller to drop the voltage going to the accelerometer. Measure with a voltmeter to be certain. Compute the current flow for you resistors to be sure that you don't exceed the current capabilities of the digital pin (40mA max; 20mA recommended). Make sure the resistors can handle the current flow, too.
When I first used the accelerometer I used the 3.3v output and tied Aref to 3.3v as well and that worked fine.
I then noticed the adxl3xx example in the ide and saw that you could slot the board into the 6 analog pins directly and naively thought the example was safe. "adxl3xx" is misleading.
