AERMEC Air Conditioner IR problems
Hello,
I'm trying to reproduce IR signals for an AERMEC Air Conditioner but I'm not able to reproduce the right RAW sequence.
I received the following IR rawcode (from the IRReceiver): Aermec_HeathON[147] = {4950,2500, 450,900, 450,350, 500,350, 500,900, 450,900, 450,350, 500,350, 500,350, 500,350, 500,350, 500,350, 500,900, 450,350, 500,850, 500,350, 500,350, 500,350, 500,900, 450,350, 500,350, 500,900, 450,350, 500,350, 500,350, 500,350, 500,350, 500,350, 500,350, 500,350, 500,350, 500,350, 500,350, 500,350, 500,350, 500,350, 500,350, 500,350, 500,350, 500,350, 500,350, 500,350, 500,350, 500,350, 500,350, 500,350, 500,350, 500,350, 500,350, 500,350, 500,350, 500,350, 500,350, 500,900, 450,900, 450,350, 500,350, 500,350, 500,350, 500,350, 550,900, 500,300, 550,300, 550,300, 550,300, 550,300, 550,300, 550,300, 500,350, 500,300, 550,850, 500,350, 500,300, 550};
using irsend.sendRaw(Aermec_HeathON, 147, 38);
has anybody had the same problem? What am I doing wrong? do you know if an IR database exists for AERMEC?
Thanks a lot!
Hello, i'm trying to do the same, i've used the IRlib2 library to parse the codes, i can easily grab codes from the remote but when i send back the same code to the hvac nothing happens.. did the same process for other hvac and tv remote and always worked.
help is appreciated.
after posting i've tried another library: http://www.progettiarduino.com/16-arduino-telecomando-ir-tsop1738.html
i've widened the recording buffer to 501 bytes and i've tried one code and .. it works!
i'll post updates as soon as i finish decoding it
Hi nmuratori, Did you decode Aermec signals? Can you post your results? Thanks!
