AES encryption error
Am trying out a AES encryption example code, but somehow it show up this error:
Arduino: 1.8.8 (Windows 10), Board: "WeMos D1 R1, 80 MHz, Flash, Disabled, 4M (no SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
D:\Desktop on HDD\AES_chien\AES_chien.ino: In function 'void setup()':
AES_chien:68:27: error: 'class AES' has no member named 'calc_size_n_pad'
   int encryptedSize = aes.calc_size_n_pad(packetSize);
exit status 1
option enabled in File -> Preferences.
I totally dont understand how this code and this library work, can someone pls explain?
this is the code example included in library
#include <Crypto.h>             // AES 128 CBC with pkcs7, RNG, SHA256 and SHA256HMAC
#include <base64.hpp>           // Base64 encode and decode without line breaks https://github.com/Densaugeo/base64_arduino
 * AES encryption with SHA256HMAC on an ESP8266
#define HMAC_KEY_LENGTH 16
#define AES_KEY_LENGTH 16
uint8_t* keyEncrypt;
uint8_t* keyHmac;
uint8_t keyHash[SHA256_SIZE];
uint8_t key[AES_KEY_LENGTH] = { 0x1C,0x3E,0x4B,0xAF,0x13,0x4A,0x89,0xC3,0xF3,0x87,0x4F,0xBC,0xD7,0xF3, 0x31, 0x31 };
uint8_t iv[AES_KEY_LENGTH];
SHA256 sha256;
// prints given block of given length in HEX
void printBlock(uint8_t* block, int length) {
  Serial.print(" { ");
  for (int i=0; i<length; i++) {
    Serial.print(block[i], HEX);
    Serial.print(" ");
  Serial.println("}");
  while (!Serial) {
    ; //wait
  Serial.printf("\n\n");
  // get SHA-256 hash of our secret key to create 256 bits of "key material"
  sha256.doUpdate(key, AES_KEY_LENGTH);
  sha256.doFinal(keyHash);
  // keyEncrypt is a pointer pointing to the first 128 bits bits of "key material" stored in keyHash
  // keyHmac is a pointer poinging to the second 128 bits of "key material" stored in keyHashMAC
  keyEncrypt = keyHash;
  keyHmac = keyHash + AES_KEY_LENGTH;
  // maximum packet length for this example is 350 bytes. A crash occurs on larger packets.
  char packet[] = "abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ1234567890\nabcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ1234567890\nabcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ1234567890\nabcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ1234567890\nabcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ1234567890\nabcdefghijklmnopqrstuvwxyzABCDEFGHI";
  // char packet[] = "1234567890 abcdefghijklmnopqrstuvwxyz !@#$%^&*()_+{|\\:\"<>?-=[];'./,";
  // char packet[] = "0123456789abcdef";
  Serial.println("On the sending side:");
  int packetSize = strlen(packet);
  Serial.printf("Packet (%d bytes):\n", packetSize);
  Serial.println(packet);
  Serial.print("Packet HEX");
  printBlock((uint8_t*)packet, packetSize+1);  //+1 to add null termination
  // random initialization vector
  RNG::fill(iv, AES_KEY_LENGTH);
  Serial.printf("Random IV (%d bytes)", AES_KEY_LENGTH);
  printBlock(iv, AES_KEY_LENGTH);
  AES aes(keyEncrypt, iv, AES::AES_MODE_128, AES::CIPHER_ENCRYPT);
  // create buffer for final message which will contain IV, encrypted message, and HMAC
  int ivEncryptedSize = encryptedSize + AES_KEY_LENGTH;
  int ivEncryptedHmacSize = ivEncryptedSize + SHA256HMAC_SIZE;
  uint8_t ivEncryptedHmac[ivEncryptedHmacSize];
  // copy IV to our final message buffer
  memcpy(ivEncryptedHmac, iv, AES_KEY_LENGTH);
  // encrypted is a pointer that points to the encypted messages position in our final message buffer
  uint8_t* encrypted = ivEncryptedHmac + AES_KEY_LENGTH;
  // AES 128 CBC and pkcs7 padding
  aes.process((uint8_t*)packet, encrypted, packetSize);
  Serial.printf("Encrypted (%d bytes)", encryptedSize);
  printBlock(encrypted, encryptedSize);
  // computedHmac is a pointer which points to the HMAC position in our final message buffer
  uint8_t* computedHmac = encrypted + encryptedSize;
  // compute HMAC/SHA-256 with keyHmac
  SHA256HMAC hmac(keyHmac, HMAC_KEY_LENGTH);
  hmac.doUpdate(ivEncryptedHmac, ivEncryptedSize);
  hmac.doFinal(computedHmac);
  Serial.printf("Computed HMAC (%d bytes)", SHA256HMAC_SIZE);
  printBlock(computedHmac, SHA256HMAC_SIZE);
  Serial.printf("IV | encrypted | HMAC (%d bytes)", ivEncryptedHmacSize);
  printBlock(ivEncryptedHmac, ivEncryptedHmacSize);
  // base64 encode
  int encodedSize = encode_base64_length(ivEncryptedHmacSize); // get size needed for base64 encoded output
  uint8_t encoded[encodedSize];
  encode_base64(ivEncryptedHmac, ivEncryptedHmacSize, encoded);
  Serial.printf("Base64 encoded to %d bytes\n", encodedSize);
  // Now on to the receiving side. This would normally be in a different skectch so we would
  // again SHA256 hash our secret key to obain keyEncrypt and KeyHmac on the remote side.
  // We would then recompute the HMAC using the received iv plus encrypted mesage and
  // compare the computed HMAC to the received HMAC. If they match, we can decrypt the message.
  Serial.printf("\nOn the receiving side:\n");
  // base64 decode
  int decodedSize = decode_base64_length(encoded);
  uint8_t decoded[decodedSize];
  decode_base64(encoded, decoded);
  Serial.printf("Received %d bytes\n", encodedSize);
  Serial.printf("Base64 decoded IV | encrypted | HMAC (%d bytes)", decodedSize);
  printBlock(decoded, decodedSize);
  // receivedHmac is a pointer which points to the received HMAC in our decoded message
  uint8_t* receivedHmac = decoded+decodedSize-SHA256HMAC_SIZE;
  Serial.printf("Received HMAC (%d bytes)", SHA256HMAC_SIZE);
  printBlock(receivedHmac, SHA256HMAC_SIZE);
  uint8_t remote_computedHmac[SHA256HMAC_SIZE];
  SHA256HMAC remote_hmac(keyHmac, HMAC_KEY_LENGTH);
  remote_hmac.doUpdate(decoded, decodedSize-SHA256HMAC_SIZE);
  remote_hmac.doFinal(remote_computedHmac);
  printBlock(remote_computedHmac, SHA256HMAC_SIZE);
  if (*receivedHmac == *remote_computedHmac) {
    // extract IV
    memcpy(iv, decoded, AES_KEY_LENGTH);
    Serial.printf("Received IV (%d bytes)", AES_KEY_LENGTH);
    // decrypt
    int decryptedSize = decodedSize - AES_KEY_LENGTH - SHA256HMAC_SIZE;
    char decrypted[decryptedSize];
    AES aesDecryptor(keyEncrypt, iv, AES::AES_MODE_128, AES::CIPHER_DECRYPT);
    aesDecryptor.process((uint8_t*)decoded + AES_KEY_LENGTH, (uint8_t*)decrypted, decryptedSize);
    Serial.printf("Decrypted Packet HEX (%d bytes)", decryptedSize);
    printBlock((uint8_t*)decrypted, decryptedSize);
    Serial.printf("Decrypted Packet (%d bytes):\n", strlen(decrypted));
    Serial.println(decrypted);
  delay(1);
Apparently, that code and that library do not work together. You might look for a library that has the called function.
Please post a link (using the chain links icon on the forum toolbar to make it clickable) to where you downloaded the Crypto library from. Or if you installed it using Library Manger (Sketch > Include Library > Manage Libraries in the Arduino IDE or Libraries > Library Manager in the Arduino Web Editor) then say so and state the full name of the library.
