AFMS v2.3
Hello. I am new to arduino and programing in general (started a week ago) but I'm doing fairly well thanks to all the tutorials out there. In advance I apologize if I use wrong terminology. I recently ran into a problem:
I am trying to make something like a sorter machine (lets say it sorts marbles). I use Adafruit Motor Shield v2.3, 5 servo, 1 stepper motor, 4 IR sensors and 3 other digital pins will be used as input to get a signal (just a HIGH or LOW). So I ran out of digital pins at this point and I need to make an emergency stop button. I can not just cut the power because the stepper will be holding some weight and if I cut the power the stepper will be able to freely spin and things will fall..
So I'm trying to use analog pin but the problem is that when I seat in motor shield the analog pins A1 A2 A3 go to 4.8V and A0 go to 0.7V. First of all is that supposed to happen? Soldering is good.
Your post would benefit by addition of some useful information. I recommend study of how to use this forum.
You have to define the analog pin as an input is your setup code and supply a pull up or down resistor depending on your button configuration.
