Hello everyone,
I am trying to add basic authentication to my project and my issue is that after doing this the client.readStringUntil('\r'); is always empty.
This was my previous code:
WiFiClient client = server.available();
String request = "";
boolean DataAvailable = false;
if (client)
// Read requests from web page if available
request = client.readStringUntil('\r');
DataAvailable = true;
client.flush();
This is what i have tried to do with basic authentication:
if (client) { // If a new client connects,
Serial.println("New Client."); // print a message out in the serial port
String currentLine = ""; // make a String to hold incoming data from the client
while (client.connected()) { // loop while the client's connected
if (client.available()) { // if there's bytes to read from the client,
char c = client.read(); // read a byte, then
header += c;
if (c == '\n') { // if the byte is a newline character
// if the current line is blank, you got two newline characters in a row.
// that's the end of the client HTTP request, so send a response:
if (currentLine.length() == 0) {
// checking if header is valid
// dXNlcjpwYXNz = 'user:pass' (user:pass) base64 encode
if (header.indexOf("dXNlcjpwYXNz") >= 0) {
// Finding the right credential string, then loads web page
client.println("Content-type:text/html");
client.println("Connection: close");
client.println();
// i have tried adding here the lines from my
// previous code but the result of client.readStringUntil('\r'); is always empty
client.flush();
// Wrong user or password, so HTTP request fails...
else {
client.println("HTTP/1.1 401 Unauthorized");
client.println("WWW-Authenticate: Basic realm=\"Secure\"");
client.println("Content-Type: text/html");
client.println();
client.println("<html>Authentication failed</html>");
} else { // if you got a newline, then clear currentLine
currentLine = "";
} else if (c != '\r') { // if you got anything else but a carriage return character,
currentLine += c; // add it to the end of the currentLine
// Clear the header variable
header = "";
// Close the connection
client.stop();
Serial.println("Client disconnected.");
Can someone please help me understand why request = client.readStringUntil('\r'); is returning an empty value after i added the authentication?
Thank you very much!
